Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv troubleshooting I have a 52" gemstar with a dvd and dish network reciever hooked up to it and for some reason it just started switching back and forth like every second from video 1 channel to the video 2 channel i've tried everything from unpluging the tv to try and reset it to disconnecting everything to see if that would help also try reprogramming and takind the batteries out of the remote control even when u press the channel buttons on the tv nothing happens it stills just switches back and forth i would really appreciate it if someone could help me with this problem
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Your keyboard is most likley bad..or tv  buttons/switch...
Posted on Oct 19, 2007
Toshiba hooked to dish struck by lighting, will not turn on, solution?
Ensure the power outlet has power. Try TV on a different power outlet. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
How do u hook up the dvd player and dish network to your tv
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
DISH Network Customer Service
Dec 10, 2010 | Sanyo DWM400 DVD Player
Does the sharp Aquos LC-52 support HDCP? I have Dish Network and for some reason can't watch any HD PPV channels, Dish Network says it's a TV issue. Can you help?
DISH Network blocks multiple video outputs on all PPV and most premium content to prevent recording, and they will tell you it is a TV issue. Ensure that your receiver only has one video cable coming out, to only one device (ie HDMI to the TV) and try again.
Oct 03, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
What would cause reciever 2 to have a much lower singal than reciever 1 on a 625 reciever foe dishnetwork
Hello there! Becki Barned with Dish Network customer service here! There are a few reasons for this. There could be a problem with the receiver itself, cabling, or a component on the dish itself. Normally, it is due to a corrupted cable, or the receiver not being able to pull in signal. Unplugging the receiver for 10 seconds in most cases, will help. Blog back if any other troubles!
Sep 26, 2010 | DISH Network DVR-625 DTV Receiver /...
No picture just sound thru dish network
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
Becki Barned
Jun 01, 2010 | LG 52LG50 52 in. LCD HDTV
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
May 30, 2009 | Coby DVD-958 Theater System
1998 Older TV, Dish Network and DVD Player I can't set up
try getting an rf modulator, they are about 20 bucks at walmart, i had to do that for my dad, his tv had the hookups but it still wouldn't work. try that you might be able to hook up the dvd, tv, and dish network plugs all in one.
Mar 08, 2009 | Protron PD-007 DVD Player
Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
