Question about Epson Stylus CX6600 All-In-One InkJet Printer
I cannot find the USB Port on my CX6600 printer
  • Anonymous May 20, 2009
    i cannot find the usb port
    Sergeant:
    Novelist:
  • 197 Answers
Lift the scanner lid and look carefully on the left side of the printer, you should see the small connection for your USB there. Make sure you feed the line through properly, otherwise you could damage the cable when closing the scanner lid.
Posted on May 16, 2009
    Champion:
  • 214 Answers
Have a look on the back. It's a small rectangle hole with 2 mitred corners, about 8mmx6mm square. It is there.
Can't print from computer
Hello. the best way to get going again is to hook up the USB cable between your printer and computer and then run your printer driver disk. If you do not have the printer driver disk, you can download it for free. Just google Epson Stylus CX6600 printer driver
Feb 12, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Cant fax
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Epson Stylus CX6600 All-In-One InkJet...
How do I hook up my epson stylus cx6600 to my computer
Kenney,
The usbport on these printers is located under the scanner assembly. Open the top of the unit as though you were going to replace a cartridge, To the front you will find the usb port. Be sure to thread it through the cable slot.
Gremlin11
Please remember to rate my assistance!
Dec 13, 2008 | Epson Stylus CX6000 All-In-One InkJet...
How do I hook up a Epson stylus cx6600 to mycomputer?
According to the setup instructions on the Epson Website there is a yellow sticker covering the USB port located under the scanner.
Dec 13, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson stylus cx6600 help!
first check whether ur printer have usb or lpt. and then check ur model may be sometimes ur printer automatically detects by xp otherwise u have to download ur printer from www.driverguide.com
Install it
Mar 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
I cant believe....
a USB cable are selling in Epson printer distributor.
Dec 25, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Cx66oo not connected to computer
Turn the volume up on your PC and switch on the printer. Does the PC do the "Bing Bong" that indicates it has recognised a USB device being connected?
If yes, delete the current version of the printer and remove the software. Go to Epson website and download all the new drivers and software for your machine.
Install the new driver first. Now try printing again. If still no good then there may be a further issue with either your cable or the printer. Try moving the cable to a different USB port on the PC. If still no good, try a new cable. If still no good, most likely a problem with the printer. Test the cable and port by using a different device.
Nov 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
