Question about MSI 955X Platinum Motherboard
Sata plugs and manual
I have a usb outlet on the front of my praetorian case, tried to upgrade my video card with an evga gts250 which will not fit due to the sata drive cords(4) which are plugged in. There are 2 other sata plugs on the board, but if we switch the plugs does the move have to be addressed in the bios? I do not have the motherboard manual. Where would I be able to get one or look at one online? Thanks a bunch. Mike H., Buffalo mha513@aol.com
  • 35 Answers
    President:
  • 1,179 Answers
You can find the info to obtain your manual at : http://www.msi.com/index.php?func=faq2show&faq_no=14 Hope this helps.
Posted on May 17, 2009
  • Roy Lonsinger
    Roy Lonsinger May 17, 2009
    See my other solution for your manual info. You should be able to move to the other SATA ports without doing anything in bios. Your bios should automatically re-recognize the change and at most all you might have to do is rearrange the boot order in bios. Hope this helps you out.
Hello, I will try to explain my problem as clear, however, as short as I can. I am building a machine off the P55V Sli motherboard (1156). Case mounted the board proberly, S-ATA's had a few issues...
there must be a video card in the first pci x *usually running x16* and the 2nd usually runs at x4. the motherboard will not post at all if there is a card in the 2nd slot but not the first (hence the beeps) you can buy right angle adapters for sata connectors if that helps and makes sense?
Mar 26, 2011 | Evga P55V SLI Motherboard w/ SuperSpeed...
Failed usb headers
1) Power down or reboot your system.
2) As the pc is restarting, press the F2 button to pull up the "Setup" screen.
3) Right Arrow to the "Advance" tab
4) Make sure that all devices are enabled
5) Arrow down to "Miscellaneous Devices"
6) Make sure "External USB Ports" is also enabled
Feb 01, 2018 | Evga X58 SLI LE (25139) Motherboard
Need Manul for ASUS SKT-775 P5QL/EPU S/L 1333 FSB
Look at the "tail' of each of the new fans.
They probably will have 2 or 3 wires going into a WHITE-coloured plastic connector. Look for 3 gold-coloured pins on the motherboard -- that will match the holes in the white connector.
The add-in video-card _should_ have a connector that fits into one of the WHITE or BROWN sockets on the motherboard, while the "spine" of the video-card fits flush on the "back" of the computer-case.
Your motherboard probably has a built-in Ethernet port -- there's probably no need to add-in a separate Ethernet card.
You probably do _NOT_ need to cite an ID/password -- just connect your Ethernet port, via an Ethernet cable, to either your router or your cable-modem or your ADSL-modem, and your computer will automatically obtain an IP-address.
Apr 05, 2010 | Computers & Internet
What is compatible with my emahcines w3050 in upgrading my video memory. What limits are on my machine?
HDMI? Oh, then you would be talking about a graphics card like this one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071689&CatId=318
HIS Radeon HD4670 IceQ
1) AGP 8X graphics card
2) Has a VGA, DVI, and HDMI port
3) 1GB of GDDR3 ram memory
4) 128bit interface
5) 320 Stream Processors
6) Core Clock is 750MHz at maximum capability
7) Memory Clock is 1746MHZ at maximum capability
It doesn't matter that your computer system ram memory is DDR Sdram. The GDDR3 graphics ram memory operates independent of the system ram memory.
Information about graphics, graphics cards, and graphics card terminology,
A) http://www.brighthub.com/video-games/pc/articles/984.aspx
B) http://computer.howstuffworks.com/graphics-card.htm
Mar 20, 2010 | E-Machines W3050 PC Desktop
EVGA x58 SLI LE + VIA VT6421A RAID card Install without os?
There are many tools you can use to install RAID stuff. For example Hirens Boot CD http://www.hirensbootcd.net/details/10.2.html - the download may be broken but google it and you should find it quickly.
(http://www.hiren.info/downloads/freeware-tools/)
Also if you need to boot from a USB then try UNetbooin or  some of the tools mentioned on the site.
This should help to install RAID there are many tools on here. What kind of fussy os has to use SATA dvd drives anyway.
Nick
Mar 05, 2010 | Evga X58 SLI LE (25139) Motherboard
I have a Gateway E2100 and would like to install an upgraded video card. Can you reccomend a slimline PCI card that would work in this PC?
EVGA Geforce 9400 512mb PCI - $70 and low profile ready so it should fit in your case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130499
Jul 13, 2009 | Gateway Computers & Internet
Monitor wont work
You were not very clear with your question. If you mean you have disabled your onboard video, then installed the new video card and get nothing then the card is not compatible with your system OR you got a bad card. If you mean you simply installed the card, turn on your computer and get nothing until you move your monitor plug back to the original port (without turning off the computer) then you must disable your onboard video by going into your BIOS settings. Follow the instructions that came with your video card or your computer to do that. Usually you get in by pressing delete or F2 while the computer boots.
Jun 06, 2009 | Evga e-GeForce 7300GT 512MB Graphic Card
GTS250 Graphics card not showing up
i checked your model at lenovo and i can't see a PCIE slot. You can verify it here http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-61495
Apr 17, 2009 | Intel Motherboard
EVGA E-GeForce 6200 Installation
Try to disable your integrated video card in your PC's bios setting. If you have done that job already or your bios doesn't support it then clean your cards pins or tiny golden terminals with soft cloth.Check whether your card supports the mother board Graphic card slot or not . like in case of "AGP slot" speeds are 2x 4x or 8x and in case of "Pci Express Slot" 8x or 16x. Check *********** board's or main board's manual as well as EVGA's manual for compatibility issues. Hope it works .don't hesitate to contact me agian. thanks
Mar 26, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
MSI 955X Platinum Motherboard Logo
100 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
