Question about Proview Hx263 26 in. HD-Ready LCD Television
I need a manual for proview product # hx263 model 2600
Cant get any picture at all with ditigal cable but can get it with direct tv. will this tv only work with hd ?????
SOURCE: proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
praky16
  • 744 Answers
SOURCE: Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 07, 2009
dave1645
  • 834 Answers
SOURCE: had a hd cable box i only have cable and tv no
no use componant or HDMI inputs
Posted on Nov 06, 2009
  • 29 Answers
SOURCE: no hd picture
This is a known fault on this panel and the samsung.
replacing the separate hd tuning block that connects to the main board will fix this problem.
Posted on May 23, 2010
bugoy31
  • 1238 Answers
SOURCE: when I turn the tv
that problem is on the back-light lamp of your LCD TV it is busted or weak need to replace it
Posted on Mar 09, 2011
I need a replacement remote for 32" Proview TV
Hi Benjamin,
Please let me know the exact model no. of your TV to give you direct link for the right replacement of remote control. It is printed on the rear cover of your unit, receipt, and on the manual.
Kind Regards,
Jdvillanueva
Nov 26, 2011 | Televison & Video
Sound no picture. When turn on quick flash blue light then nothing. Product#RX326 model 3200 made July 2005 bought used
Backlight inverter is bad. You will need a direct replacement.
Search shop jimmy.com and encompass parts.
The backlight inverter is the part that allows for the illumination of the tv itself.
Thank you
Jul 07, 2011 | Proview Televison & Video
Sound but no picture
Check your video Inputs, use the source o input button on your remote, and toggle to the correct input, IE HDMI, DVI, or component.
Jun 11, 2011 | Proview Hx263 26 in. HD-Ready LCD...
Color is messed up...very green looking screen, appears red colors appear green
Do you have extra hardware connected to the TV? If so, it could be a problem with the cable/connections.
Mar 07, 2011 | Proview Hx263 26 in. HD-Ready LCD...
Green lite on screen flashing no picture no sound
U know basic electronic's and know soldering?Ur power supply board is defective have dead leakage capacitors,these capacitor around the power supply board they bulges up it top,or puff it up on it top.Replaced these defective gases leakages capacitors,u tv will get it power back and funcstion normally.Or tries this websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 30, 2010 | Proview Hx263 26 in. HD-Ready LCD...
Need to program the remote control from Comcast cable
Hi would need to know the model of the remote to get the correct code. Here is a link to the codes>
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Jan 31, 2010 | Proview Hx263 26 in. HD-Ready LCD...
MISSING POWER CORD
95% of all LCD and Plasma sets use the standard PC cord.
Jun 27, 2009 | Proview Hx263 26 in. HD-Ready LCD...
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview Hx263 26 in. HD-Ready LCD Television Logo
264 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
