Question about JVC GR-D370 Mini DV Digital Camcorder
Playback jumpy Every time i try to play back my videos they are jumpy do i have the shutter speed set to the wrong speed or something?
  • 156 Answers
NO.PLEASE TRY TO CLEAN THE DRUM ASSY
Posted on Oct 25, 2007
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Jumpy video playback at regular speed. what can I
This sometimes happens on computers with insufficient RAM.
Apr 27, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
Jumpy Video
I had the same problem while watching back thru Quicktime. Other post I have read people are having this issue on macs. Seems this is an Apple issue and not a Flip issue. When I play back thru windows Media Player everything is fine.
Aug 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Too fast playback of video cassette
Initially, I am inclined to think that nothing is wrong. It is just most likely that that particular tape was recorded in a different speed other than what your VCR is capable of playing. This is a form of compression wherein a longer recording/playing time is squeezed into the same type/kind of tape. The various settings are SP, LP, EP or even an XP. Pls click here to give you an idea of the recording time/speed at different settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | JVC HR-J461MS VHS VCR
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Camcorders
Almost any new digital camcorder will work great, but you want to make sure it has a high speed shutter setting.  Set the shutter speed as high as possible (which means you'll need a lot of light... day light is perfect).  You're still only shooting 30 frames per second, but each shot will be sharper (less motion blur) as the shutter speed increase.  High-end cameras can go up to as much as 1/10000th of a second, but even 1/500 would be great.  Standard, default shutter speed is 1/60th.
For playback, you can use the same camera with a remote control.  Just press play, then just before the swing press pause.  Then use the frame advance button to move 1 frame at a time.  Multiple presses of the frame button will increase the speed... to slow motion.
Apr 24, 2008 | Video Cameras
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Wont playback videos taken
Some common faults with most camcorders and video playback units:
Dirty heads
Failure in the head assembly
Failure in the head pre-amp section
Failure in the main video processing section
Internal system timing fault
Servo lock fault condition
uPC is hung in its operation and requires a re-set
The unit should be properly checked at a service center to determine the exact cause of failure.
Jerry G.
Jan 11, 2007 | Canon Elura 85 DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder Logo
160 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
