Question about Eddie Bauer Musical Rocking Bassinet 10330WOW Crib
Compant no longer carries this specific model. The pilot holes were drilled by manufacter too close/crroked so when it was put togther it chipped the wood,. I now need replacement part. It is the long
The bottom piece on my Product#10330 Eddie Bauer Wood bassinet was screwed too close to the edge by the manufactuer so when it was put together it chipped the wood on both ends of the one piece. I need to know how I can get a replacement part.
  • Anonymous May 16, 2009
    The wood frame is cracking at the edges where the bolts attach. Do they make a replacement part?
  • 59 Answers
You can fix this with wood glue - But if you want replacement parts you have to go back to the manufacture.
Posted on May 16, 2009
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
WHAT THE EXPRETION "CORE-BORED" MEANS
when drilling cement floors to add new mounts for equipment theres two ways to do it , Impact = useing a impact drill to chip cement out of hole Or core boring , this uses a hollow round drill to slowly saw the cement out of hole this tends to make a less ragggy hole in cement so hole is smoother and has less fractures in it (takes longer to do than first method )
Sep 07, 2014 | Drills
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
Mar 23, 2013 | YouTube Videos
Just received a thermocast sink (kitchen) but it was shipped with one hole andI need four. can I drill holes or should I ship this back?
Yes, you can drill them with most any hole saw...just make sure to only use the pilot bit when drilling the pilot hole and then place the hole saw on after the pilot hole is drilled...
Do not apply much pressure to the bit... only enough to give a bit of a cut from the bit as you are drilling the hole.
heatman101
Jul 14, 2011 | International Thermocast Corp Thermocast...
I'm not sure how to put the string swing ukulele hanger inthe wall!!
It should come with mounting hardware, including screws and anchors. You'll need to:
1. Locate a stud in the wall.
2. Position the hanger where you want it.
3. Mark where the screw holes are.
4. Using a 1/8 in. drill bit, drill pilot holes on the marks you just made.
5. Put the hanger back up to the holes, and insert the screws.
If you have to use wall anchors, these should go in after drilling the pilot holes, but before screwing down the hanger.
If you need any clarification, let me know!
Hope that helps!
Feb 09, 2011 | String Swing Ukulele Wall Hanger w/ Wall...
How to repair a lower ball joint on the passenger side
Hi.
1. Raise and support vehicle.
2. Remove tire and wheel assembly, then install modified outer seal protector No. J34754, or equivalent, Fig.3 .
3. Remove lower ball joint cotter pin and nut, then loosen ball joint from steering knuckle using tool No. J-29330, or equivalent.
4. Position a suitable pry bar between suspension support and lower control arm and separate lower ball joint from steering knuckle. On some models, it may be necessary to remove nut attaching link to stabilizer shaft.
5. Locate center of rivet body and mark with a center punch.
6. Using a 1/8 inch drill, drill pilot holes completely through rivets. Using a 1/2 inch drill, drill final holes through rivets to ensure fitting of new ball joint.
7. Remove ball joint from lower control arm.
8. Assemble new ball joint to lower control arm with bolts provided in service package, Fig.9 . Tighten bolts to specifications.
9. Insert ball joint stud into steering knuckle and tighten nut to specifications, then install cotter pin.
10. Install wheel and tire and check front wheel alignment.
I hope this helps you.
Thanks.
Nov 28, 2010 | 1994 Pontiac Grand Prix
I have a composit kitchen with knock outs for 4 faucets. How do I knock them out?
Do NOT try to knock them out! The correct way is to drill them out as needed for your particular faucet. Refer to your installation instructions for your faucet to determine which holes need to be drilled out. There is a school of thought that it is best to drill them all and use a hole cover on those you don't use since once the sink is installed you will no longer be able to drill them at exactly factory locations.
You will need a 1-3/8" hole saw (my preference is Lenox brand # 30022), an arbor (a special drill bit for the hole saw Lenox brand # 2L), and preferably a varible speed drill.
Turn your sink upside down and place onto a clean padded surface to protect the finish and is also a padding that you can bear to throw away. Locate the center of the hole to be drilled. If there is no dimple from the manufacturer at dead center, you will have to give it your best guess. Mark that spot and with the arbor securely mounted into the hole saw, begin drilling at 1/4 to 1/2 speed of the drill, until the tip of the arbor had drilled completely through. Remove the hole saw and turn the sink right side up. The hole that the arbor made in now called a pilot hole and will guide your hole saw perfectly. By drilling from the top side you eliminate any chipping. Insert arbor into the pilot hole and begin drilling using light to moderate pressure until the hole saw has drilled through. Be careful! As you sense you are nearly through the drilling, only use light pressure so you don't lose control of the drill when the saw pops through and accidentally smack your sink.
May 31, 2010 | Swanstone KSDB-3120 Compact Double Bowl...
Can you drill a hole for a soap dispenser in a thermacast sink
Yes you can...
Use a good sharp hole saw like you would use for wood or metal...
It is best to drill the pilot hole with just the 1/4" pilot bit before you put the hole saw on and drill the big hole. Use patience and gentle pressure and you'll be through in a minute...
heatman101
Apr 16, 2010 | International Thermocast Corp Thermocast...
Will hammer but not drill model te52
If it drills in the air but stops when you put it into concrete then the clutch is worn out. If it will not turn at all it could be stripped gears. Unfortunately Hilti no longer carries parts for that model.
Oct 01, 2009 | Hilti Drills
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Logo
325 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
woodzowl307
ray gallant
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
