Question about IOGear GCS632U 2-port KVM Switch
DELL STARTUP I AM USING THE 2 PORT KVM ON 2 DELL MACHINES, THE FIRST A OPTIPLEX 320 AND A DELL PE2900 SERVER. WHEN I START THE OPTIPLEX, IT LOCKS UP ON STARTUP, WILL NOT EVEN GET PAST THE SYSTEM CHECK BEFORE WINDOWS LOADS, UNLESS I SWITCH THE KVM TO THE SERVER UNTIL THE OPTIPLEX GETS PAST INITIAL STARTUP.
  • 1 more comment
  • faithsmom Dec 05, 2007
    I also have the same problem, using the IOGEAR 2 port KVM switch and a Dell Optiplex 320. The Dell just hangs and the DELL startup screen.
  • dandaph Dec 13, 2007
    Have the same problem in Dell Optiplex. Tried updating the Bios and even other exact machines. System will some time start and sometimes hangs at bios screen.
  • Jonathan Aug 08, 2008
    Same problem here as well. I'm using the IOGEAR KVM with a dell Optiplex 210l and an Optiplex 320. The Optiplex 320 will not boot unless I uplug the USB portion of the KVM. I've upgraded to the latest bios and drivers and still have the same problem. I also have problems getting a complete image backup of the Optiplex 320 when using Acronis10. The image won't transfer out to a USB external hard drive. It freezes part way through. I support 5 Optiplex 320s at my work and all of them have had problems. It seems like the 5 year old Dell OptiPlex 160L are more stable than the newer 320s. I'm ready to through the 320s out the window. Urrggh!
    Problem Solver:
  • 5 Answers
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Posted on Jan 17, 2009
I had the same problem with a Dell Optiplex 320 and Cables to Go KVM (USB version). Tried the solution of making sure the KVM was set to the other computer (luckily not an Optiplex 320), when starting the Optiplex 320 and wait a couple of minutes to allow the 320 to boot up completely. When I swithched the KVM over to the 320, everything worked fine. Thanks for the tip.
Posted on Feb 04, 2010
Keyboard failure in dell optiplex 320
Too many keystrokes are being entered during POST (what your computer does before booting into your operating system) or a problem with your keyboard connected to the PS/2 port, or a problem with the port itself.
Replace/clean/fix/prevent cat from stepping on keys of the keyboard to resolve issue.
Oct 10, 2010 | Dell OPTIPLEX 320 (MH651) Motherboard
The KVM is unresponsive, meaning the buttons are no longer operating the way they should to go from one server to the otehr no reaction.
try tapping scroll lock twice then arrow keys. sometimes you need to start the server/computer with the kvm plugged in to get the computer to "recogize" the KVM is there. otherwise it looks for other devices Always start the computer with KVM on the respective channel. Then use it to switch. Cheers.
Aug 24, 2010 | HP (336045-B21) (336045B21) 16-port KVM...
What are the keystrokes for a dell 582rr kvm?
Have you tried pressing Ctrl twice and then the port you want to control? I can't find the exact answer for you but here are few more;
1. Scroll lock twice and the port number you want to assign.
2. Numlock twice and the port number.
Same sequence as done with Ctrl key. (press Ctrl key twice and the desired port number).
Hope one of these will definitely work for you.
Good luck.
Thanks for using FixYa.
Jun 19, 2010 | Dell (582RR) 16-port KVM Switch
Help me please..my server dell PE2900 can't start..it's stoping in BIOS, but no warning code in display, in monitor just display DELL BIOS Revisions 2.0.1
remove the on-board system battery for 10 minutes and replace, if that doesnt fix it, replace the battery completely. you can get one pretty cheap at newegg.com
Dec 09, 2009 | Computers & Internet
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
Usb ports on 1703fpt do not work
you have to connect the monitor with a usb cable to your computer, then you can use its usb ports, it's just a hub.
Mar 28, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
KVM functionality
This happens on KVMs, some more than others. I have a couple of Avocents that work great with Dell and HP servers, a Belkin OmniView that works great with two Dells and OK with a home built. Bottom line is some switches work better than others just like some PCs seem to behave better than others. If you?re looking for suggestions I would stay away from the cheaper $50 and under switches unless you find a good, used, guaranteed one somewhere. I like the Belkin OmniView and Advocent (really expensive, meant for servers and other medium sized sites). I would stay away from LinkSys, they make good wireless equipment but haven?t heard much good about their KVM switches. The original post was a few months ago so this is really intended to help anyone in the future who is researching a similar problem and winds up here.
Apr 26, 2007 | Linksys ProConnect Compact KVM Switch...
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
1,353 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
