Question about Craftsman Garden
Breakdown of transmission on craftsmen 5HP rear tine tiller
Can not remove main belt pulley from shaft.I have taken set screw out and i'm able to get pulley down the shaft a ways but can't get the last inch or so. have not taken keyway out. any tips on how to get it the rest of the way off.Thanks Ron
    Problem Solver:
Little grease on the shaft and some work was able to remove pulley. Found input pinion, tine sprocket and gear all missing some teeth. check with sears and these parts are no longer available. Can anyone tell me where i might find or locate replacement part i need for this tiller?
Posted on May 19, 2009
How to replace belt on modle #rel4434awd dryer
Unplug machine. Remove lint filter. Remove the 2 phillips head screws under filter. Raise top by pressing in on clips with putty knife or flat screwdriver. Clips are just underneath top in front about 3-4 inches from each corner. Lean top back against wall. Unplug wires from door switch. Remove the two 5/16 inch screws holding front to cabinet. These are located in front about 3-4 inches down from top. One on each side. Lean front forward and lift up. Set front aside. Now look underneath drum and you will see belt. It goes around idler pulley and motor pulley. Study how it is on closely as you will want to install new one the same way. Flex idler pulley towards motor. This will loosen belt so it can be removed. Put everything back together in reverse order. It is easier to take apart than to put back together, so study steps you take appropriately. Hope this helps.
Oct 12, 2017 | Dryers
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
How to change belt on ilco 008b mini-mite key machine
To remove or install a belt on the Ilco 008, the shaft must be slid out of at least one bearing. If there is a guard cover over the pulley, remove it. Loosen the setscrew(s) on the cutter shaft pulley, and slide the shaft to the left. Mine is an older model, with no guard and the belt can be changed without removing the shaft completely.
After putting a new belt around the pulley, slide the shaft back into the right-hand bearing.
Be sure the pulley set screws are aligned with the flats on the shaft and that there is minimal end play and the cutter turns freely. Tighten the set screws and stretch the belt over the motor pulley.
Apr 22, 2014 | Locks & Locksmithing
Replace blower belt
unplug it,open the door,remove the two phillips screws that hold the door on and remove the other two on the other side,remove the door and pull the front panel off,just tilt the top of panel out,remove the four 5/16 inch screws that hold the front bulkhead on,then remove the top screws and the L bracket on top,remove the front bulkhead,pop off the metal wire holder on the right side and stick the bulkhead on the right side of the machine so you can remove the drum,lift the top panel up a few inches and slide out the drum,you'll see the mark on the drum from the old belt,put the belt on the drum ribs down against the drum,slide the drum back in,grab the belt,put it under the belt pulley,pull the pulley over to the motor and connect the belt on the motor shaft,put the dryer back together the same way you took it apart,you'll notice two short screws,they go into the holes that have a space around the hole,one goes in the bottom and then the other opposite side up top.hope this helps.
http://www.youtube.com/watch?v=1eeJvqhHEYY
May 16, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Trying to find a maintenance manual (exploded view of transmission) for a craftman rear tine tiller (may have been made in Canada), with 5hp Brigs & statton (1985 from motor serial). The tiller serial...
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.Try 917. as the first part of model #.
RGS
Mar 17, 2011 | Craftsman Garden
The rear tine seals are leaking ive taken the bolts out but the tines will not come off what can i do
You could try putting the tiller to use, preferably where it will have to work hard to till the ground it unsuccessful you may need a torch and some good old fashion luck to loosen tines from shaft. Now consider this; if the bearings are worn so that the shaft is loose new seals will not hold up and you will risk doing further damage to the worm gear located on rear shaft and possibly other damage to your transmission from contaminated oil.
Mar 04, 2011 | Troy-Bilt Pony Garden Tiller
TILLER WILL START/RUN BUT BLADES DON'T MOVE..TILLER PART DON'T MOVE? MTD21AH413B129287-424
Hello, W/D here.
The motor drives a belt, and the belt drives a pulley that causes a chain to drive the tines (blades). For the belt to drive the tines, an idler pulley has to put tension on the belt. This is moved into position by a lever that pulls the pulley into tension on the belt, and tension is maintained with a spring when the lever is locked into place.
1. Make sure that the tines will rotate with the belt off. If there is difficulty, check for debris holding the tines (roots, etc.). If necessary, remove the cap covering the chain cover inspection port, and with the machine tilted back, observe for proper operation of the chain while moving the tines by hand. Lubricate the chain according to your manual. If your chain is not working properly, disassemble down to the chain case, and inspect the chain and sprockets. Chain is radily at places like Motion Industries, WW Grangier, or a bicycle shop. Often overlooked, check that the pulley set screws are tight, and causing the shaft attached to it to actually rotate. Check the pins and locking cotter pins in the tines, make sure that they are pinned to the shaft.
2. Check the belt. An old belt can stretch to the point where it will no longer work. The "V" belt can also wear down to where insufficient friction can be applied to the driving or the driven pulleys to cause it to rotate.
3. Check the condition of the idler pulley and spring. Make sure that the lever places tension on the belt. It should be somewhat difficult to engage the idler pulley when the belt is new. You may have an adjustor on the idler that will tighten the belt.
Best regards, --W/D-- Please provide feedback for our solutions so that we may continue to improve in helping others. Thanks.
Feb 24, 2011 | Mtd Products Yard Machines 158CC Tiller
How can i remove the drive pulley on the 12.5 briggs and stratton
Hi Steve, There should be an allen head set screw (Sometimes 2) that has to be removed before the pulley will come free. One set screw should be directly above the key way "key" and the second one (If installed) will be within 90 degrees of the one securing the key. Also take a piece of 100 or 120 grit sand paper and sand off the rust areas on the old crank shaft. Occasionally it does require a puller to get them off but usually you can tap gently the pulley every 90 deg (not on the pulley V belt drive area) and it will come free.
This should be a 13HP 2 cyl engine.
Depending on the type pulley they are using. Some of them have a collar on the crankcase side of the pulley that will also have to be removed. (again secured with a set screw possibly 2)
If it is really stubborn you can and should use a puller to remove the pulley. Be very careful if you do have to use a puller; not to damage the V-belt drive area of the pulley.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
356 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
