Question about Dryers
Poor heat wondering were the fuses are located and what are the common problems that could fix this issue
  • 31 Answers
Most dryers have 2 heating coils 1 maybe burnt out. hopes this help u
Posted on May 16, 2009
2001 dodge caravan gauge cluster not working
Check to see if trailer wiring was wired correctly, I've seen similar issues where incorrect trailer wiring has damaged the vehicle wiring and cause electrical issues. Lets hope this hasn't happened. Unplug the trailer and test all circuits for functionality.
Nov 11, 2011 | 2001 Dodge Grand Caravan
The microwave does not heat up the food but everything works except the fact that it don't heat up the food
Hi!
The most common cause of the problem you described is a burned fuse. It is normally located inside the case, directly on a wire leading from the transformator to the magnetron. If you are not sure about those parts, please get a professional to fix the issue.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
Subaru wrx impreza showing fault code p0037. how do i fix this fault which sensor is it and where is the sensor located?
http://helpforcars.net/obd_codes/codes.php?code=P0037
It's an O2 sensor according to the above link, and it is bank 1 sensor 2 low, the 2 meaning that it is downstream past the catalytic converter but not on the manifold.
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Faulty Engine Control Module (ECM) Possible Solution Tech Notes The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors.
Good luck on this repair.
Jan 01, 2011 | 2001 Subaru Impreza
Runs but wont heat so was wondering where the 2 house fuses are located...btw already replaced igniter
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Frigidaire GLGQ2152ES Gas Dryer
I cannot find the fuse box for the heated seats in my Jeep Grand Cherokee 2000. Also the "thing" that tells me when I need an oil change, which direction I'm going, etc. is no longer changing when I push...
The heated seat fuse is located in the junction block behind the left side of the dash. It is fuse number 20, a 10amp fuse. As for the driver information center not changing the display when you push the button, I believe this is a single unit and a relatively common issue ( I have a Grand Cherokee in my shop, for a different problem, and it is doing the same thing). My guess is that the entire info center needs to be replaced to fix the issue. Good luck!!
Jan 27, 2010 | 2000 Jeep Grand Cherokee
Not getting hot
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 18, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool oven
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jun 22, 2009 | Whirlpool GH4155XP Microwave Oven
Will not heat!
Hi!
In most of the cases, this is usually due to a bad magnetron, the other time is sometimes a bad high voltage diode which you have already replaced.
Most of the common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay or a bad door switch. Other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common. Please check all these to resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 21, 2009 | Microwave Ovens
Poor heat
Hi, Have you checked the venting to the outside? Is this gas or electric? If it is gas, it could be coils on top the gas valve. I want to help.
Vic
May 16, 2009 | Kenmore 73952 Gas Dryer
Ge spacemaker runs but wont heat
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dryers Logo
59 people viewed this question
Top Dryers Experts
