Question about Toshiba Satellite A65-S1068 Notebook
Display driver (ati2dvag.dll) stuck in an infinite loop
I have a Toshiba Model A65-S1068 which came with a display driver Mobility Radeon 7000 IGP. The computer keeps crashing because of an error with the file (ati2dvag.dll) in that it is stuck in an infinite loop.
I have tried to correct to no avail. I believe this driver is now discontinued but I cannot find out what to replace it with. I have tried updating the driver but it doesn't work.I even tried to update the display adapter but keep getting a message that I need an installation disc to do something with the file-(-atimtag.sys). As you can problaby tell I am a neophyte so any explanation will have to be very generic
How much GB does the toshiba satellite have?
Here is the specifications of the Toshiba Satellite A65-S126
  • Built-in Devices Wireless LAN antenna , Stereo speakers
  • Width 13.5 in
  • Depth 11.1 in
  • Height 2.1 in
  • Weight 7.7 lbs
  • Localization United States
  • Notebook type Desktop replacement (7.5 + lbs.)
  • Wireless capabilities IEEE 802.11g , IEEE 802.11b
  • Processor
  • Processor Intel Celeron 2.8 GHz
  • Data Bus Speed 400.0 MHz
  • Chipset Type ATI Mobility Radeon 7000 IGP
  • Cache Memory
  • Type L2 cache
  • Installed Size 128.0 KB
  • RAM
  • Installed Size 256.0 MB / 1.25 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor SO DIMM 200-pin
  • Configuration Features Provided memory is soldered
  • Storage Controller
  • Storage controller type IDE
  • Storage
  • Floppy Drive None
  • Hard Drive 60.0 GB - 4200.0 rpm
  • Hard drive type Portable
  • Optical Storage (2nd)
  • 2nd optical storage type None
  • Optical Storage
  • Type CD-RW / DVD-ROM combo
  • Read Speed 24x (CD) / 8x (DVD)
  • Write Speed 16x
  • Rewrite Speed 4x
  • Display
  • Display Type 15.0 in TFT active matrix
  • Max Resolution 1024 x 768 ( XGA )
  • Widescreen Display No
  • Color Support 24-bit (16.7 million colors)
  • Video
  • Graphics Processor / Vendor ATI Mobility Radeon 7000 IGP Shared video memory (UMA)
  • Audio
  • Audio Output Sound card
  • Audio Codec Realtek ALC250
  • Compliant Standards DirectMusic , DirectSound , DirectSound3D
  • Audio Input None
  • Input Device(s)
  • Input device type Keyboard , Touchpad
  • Telecom
  • Modem Fax / modem
  • Max Transfer Rate 56.0 Kbps
  • Protocols & Specifications ITU V.92
  • Networking
  • Networking Network adapter
  • Wireless LAN Supported Yes
  • Data Link Protocol Ethernet , Fast Ethernet , IEEE 802.11g , IEEE 802.11b
  • Compliant Standards IEEE 802.11b , IEEE 802.11g
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 (total) / 1.0 (free) x PC Card - SO DIMM 200-pin , 1.0 (total) / 1.0 (free) x Memory - Type II
  • Interfaces 1.0 x Headphones - Ethernet 10Base-T/100Base-TX - 25 pin D-Sub (DB-25) , 1.0 x Microphone - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 1.0 x Parallel - Output - RJ-11 , 1.0 x Network - Phone line - Mini-phone 3.5 mm , 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm , 1.0 x Modem - Input - RJ-45 , 1.0 x Display / video - VGA - 4 pin USB Type A , 3.0 x Hi-Speed USB
  • Miscellaneous
  • Features Power-on password , Hard drive password , Security lock slot (cable lock sold separately)
  • Compliant Standards ACPI , Plug and Play
  • Power
  • Power Device External
  • Voltage Required AC 120/230 V ( 50/60 Hz )
  • Power Provided 90.0 Watt
  • Battery
  • Technology Lithium ion
  • Installed Qty 1.0 / 2.0 (max)
  • Capacity 4300.0 mAh
  • Operating System / Software
  • OS Provided Microsoft Windows XP Home Edition
  • Software AOL , Drivers & Utilities , ArcSoft ShowBiz DVD , Norton Antivirus 2004 (3 months subscription) , Toshiba Custom Utilities , Microsoft Office OneNote 2003 , Microsoft Works , AT&T WorldNet Service , Toshiba Touch and Launch , InterVideo WinDVD 4 , Toshiba Notebook Maximizer , Toshiba Speech System , Toshiba ConfigFree , Adobe Acrobat Reader
Sep 13, 2011 | Toshiba Satellite A65-S126 Notebook
I just uptaded my display driver, ATI mobility radeon 7000 igp, and i try to open a game and it keeps saying a graphic accelerator is needed, which never happened before
intstall the Cd software driver and set your display setting on your desktop or you have to turn off your PC before it affect
Aug 13, 2011 | Computers & Internet
Ati2dvag.dll blue screen error and dont shut down the PC
It's a problem with the video driver, device driver. ATI
Here's the fix for the infinite loop problem caused by ati2dvag.dll that has worked for some others.
Right click on My Computer
Choose Properties
Choose the Hardware(Tab)
Choose Device Manager(button)
Click the [+] next to System devices
Right click on CPU to AGP Controller
Choose the Update Driver(button)
Select Install from a list or specific location (Advanced)
Choose Next(button)
Select "Don't search. I will choose the driver to install."
Choose Next(button)
Select PCI standard PCI-to-PCI bridge
Hit Next(button)
Hit Finish(button)
Reboot.
This should resolve your issue.
Jul 02, 2010 | Computers & Internet
Ati2dvag infinite loop how do I fix this
This seems to be a problem with the video card driver as ati2dvag is a part of it. What you could do is go into safe mode. Insert the drivers disc for your video. Reinstall the driver for your video card.
To go to safe mode just restart the computer and continuously pres f8 until you see the advanced options menu then press the arrow keys to highlight safe mode. Then press enter.
Apr 29, 2010 | Toshiba Satellite A60 Notebook
I received the following message on my graphic card ati radeon 200m series: there is an infinite loop on the file ati2dvag. And the errors numbers was: *** stop: 0X000000EA (0X847ACA 20, 0X0X84898F60,...
You should go to ATI's website, look up the video card you have, and download the newest software drivers for it. Video drivers can often cause blue screens and system errors when using an old version of the software.
Go to this website:
http://www.amd.com/us/Pages/AMDHomePage.aspx
When you get there, in the upper right hand corner there's a download section for software drivers. If you follow the menu, it will allow you to download the newest software for your video card. Good luck!
Aug 04, 2009 | ATI Mobility RADEON Graphic Card
ATI Radeon IGP 340mM/345M display driver or software needed..
Go here:
ATI Catalyst 8.2 - ATI Radeon - XP
Then, near the bottom of the page, click on:
Individual driver download packages, ATI Multimedia Center, Avivo™, and Korean full package and download the Catalyst Control Centre package (download 2 of 3)
Here is a direct link, but i don't know if it will re-main active:
AMD GAME! Drivers and Utilities
Then click on "Catalyst Control Center (English)"
This package will only install the ATi CCC. I personally have found that the ATI CCC doesn't like older cards, but some people have had luck getting it to work. If it doesn't work, you'll either have to find an older Catalyst Control Center, such as the one bundled with the Catalyst 4.10, or go back to using an old version of ATi Catalyst Control Panel.
Apr 29, 2008 | ATI Mobility RADEON Graphic Card
Toshiba Satellite A65-S1068 Notebook Logo
540 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
