Question about HP Pavilion zd8000 Notebook
HP Pavillion zd8000 Wireless Device does not show up or Connect
I have had my laptop for about 4 yrs now with no real problems until it was getting hotter than normal.
I Sent it in to the local PC Repairer/Parts supplier and was told that 1 of the cooling fans was no longer working and a replacement was not able to be sourced. They suggested an under laptop USB Fan cooling tray with 3 additional fans built into it and 4 USB outlets aswell.
$28 bux later no problems.
My kids use the laptop and i didn't notice it but they were complaining about No net connection, i said yeah yeah and finally tried to get it working.
I had to put a USB netcomm wireless stick into mit to get the net up !!
Just wondered how to see if it is working as it does not even show up in the system devices anymore.
I'm not very PC literate so a Laymans wording may have to be adopted for me Sorry in Advance :/
Cheers 44 44 Bro :)
  • 696 Answers
If it's not showing up in device manager it may have been unintentionally uninstalled or the built in wireless card may have failed. In either case the simplest way to test is to go into your Start menu, then All programs, then either PC Help & Tools or System Recovery folder. Inside that folder one of the programs will be for application and driver install. Follow the prompts in that program to re-install drivers, then select the wireless driver from the list it gives you. If the card has just been uninstalled or the driver for it has been corrupted this should remedy the problem.
If this doesn't work chances are the card is dead and would need replacement. They, like the fans, are tricky to find but you may have luck on eBay. For convenience you can just use the netcomm wireless stick as it is esentially the same but i would recommend installing it in the Nomad port if you model has it(look on the sides for a movable plate, if you look inside the port you will see a USB port at the back of the Nomad Port) this will keep the USB stick inside the shell of the laptop which will reduce the chance that it gets bumped or snagged and damamged when you move the laptop.
Hope this helps FixYa,
Chris
Posted on May 17, 2009
My HP zd8000 xp is receiving wireless and when hard wired will not connect to the internet. Could this be configuration problem I have run diagnostics but to no avail.
Go to device manager either control panel system or right click on computer and click on properties scroll down to network adapters and see if there is a re flag on your device if it is click on it to enable.
Jan 26, 2011 | HP Pavilion zd8000 Notebook
I can not turn on wireless to my hp pavilion zd8000
You have a number of options:
1. Make sure the wireless switch is in the "on" position. This means that the switch is slid to the right. If it is, and the light is blue, then the wireless is working just fine, you just need to connect to a wireless router. However, if the light remains orange...
2. If you have Vista, go into the start menu and right click on "Computer" (XP, right click on "My Computer" on the desktop or where ever you stashed it) and click on "Manage" in the drop down menu. After you do this, you will see a menu on the left, double click on Device Manager (6th item down). This will open another list of items. You need to go to "Network Adapters". This drop list will tell you whether or not the wireless card is being detected. Should say something like "Broadcam 802.11 b/g WLAN". If you see that, the computer is detecting the wireless card and your wireless should be working (however, if it is detecting it and the wireless light is still orange, check the switch again, if it is switched on, then you are about to have a motherboard problem). If the wireless card is not being detected...
3. You either have a HDD, wireless card, or motherboard problem (more often than not it is the motherboard, and you would be hard pressed to find one cheap). If you want to simply try to replace the cheaper parts first and hope that works, start with the wireless card, then go into the HDD, after that, obviously, the motherboard. But I will tell you from experience, that it is more often than not, a defective motherboard.
Apr 12, 2009 | HP Pavilion zd8000 Notebook
No wifi after re-load of xp system software
Did you reinstall the drivers for the device? Check the Device Manager for your system and see if Windows sees the wireless device. If you have a red X, the device is disabled; if you have either an unknown device or the wireless device with a yellow dot with a black exclamation point, then either the driver is not installed, or the driver is improperly installed.
Mar 24, 2009 | HP Pavilion zd8000 Notebook
Startup failure and beeping, 4 or 3
your new ram might not be compatible,try to leave old ram and turn on computer
Oct 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavillion zd8000
check connections first..then go to the control panel and check in systems device manager
Feb 18, 2008 | HP Pavilion zd8000 Notebook
My batterie is not taking charge
buy new replacemnt batery 1st ok maby new adpoter power
Feb 02, 2008 | HP Pavilion zd8000 Notebook
Bluetooth connection problem
The computer have 3 buttons. One is the DVD, the second is de Media Player, and the third is the wireless devices switch. If this button is not lighted, all wireless connections are off (both WIFI and Bluetooth).
Dec 08, 2007 | HP Pavilion zd8000 Notebook
Wireless connection no longer works after vista upgrade
HP uses "branded" wireless modules,which means it's got to be HP or it doesn't get to play.
Does device manager see the wireless device? I've had similar situations with the 8000s. Always the driver or the wireless utility was the problem. Try letting windows manage the device, or if you already are, disable that and use the devices utiliy to manage it.
BTW, most systems consider BT as wireless.
Good luck, hope that helps
Nov 25, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
1,079 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
