Question about Acer Aspire One Netbook 8.9" Notebook
Can't start up my new Acer Aspire One (mini) even on the battery or AC mode. Only the little red battery light comes on....
  • Acer Master
  • 32,281 Answers
If it is brand new, then you have warranty, I suggest you return it to the supplier to get it fixed, because if you do something to it you might void your warranty.
Posted on May 17, 2009
My acer aspire will charge a battery but wont power up when i plug in the ac adapter the battery light will come on but no ac light will not power up in battery or ac
Does the laptop come on when you plug in the mains and take out the battery? If it doesn't then it could be a faulty power switch.
Sep 06, 2010 | Acer Aspire 7720 Notebook PC
Have a acer aspire 5520,it has developed several problems,1, will often freeze on full screen mode,have to shut it down and restart,2, will keep on shutting down after battery light starts flashing,will...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5520-5908 Notebook
Aspire One notebook won't power up. If I hold down the power button with the battery in, I can get the indicator light to blink red, but no start up. Have tried to remove battery and left it alone for...
Try to power up with the battery charger cord plugged in and attached. Then you can use AC power while the battery charges. Also check your power options. When the battery light turns green it is done charging. Then try using the battery alone again.
Feb 28, 2010 | Acer Aspire One PC Notebook
My acer aspire 5520 will not start. the battery light is on and is red.have the ac cord in and it still will not turn on. it came on once for about 20 sec. but long so i could boot in safe mode. please...
just conncet the main power and keep as it is for 10 - 20 minutes let the battery get charged. latre on try to swicth on the laptop .if you still facing the problem then remove the battery from laptop and directly switch on main power.
Nov 27, 2009 | Acer Aspire 5520-5908 Notebook
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
How can I unlock the keyboard and mouse on a acer aspire 300
Try starting the computer in safe mode by pressing the F8 key repeatedly on boot. The start up menu will appear. Chosse safe mode and run an antivirus and antispyware program in safe mode. Your system is freezing and that is why your keyboard is not working. You should find that the keyboard and mouse will work properly while you are in safe mode. I suspect that something is stealing your available resources when you start in regular mode.
Aug 02, 2009 | Acer Aspire 4315 Notebook
No Acess to Acer Aspire One
What little red light is on? Oh, let it charge up first. That light should be green. Hope that helps.
May 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
Acer aspire 3680 - new out of box won't boot
NEED TO DEL PARTIONS MAKE NEW ONES FORMATT THE HD THEN INSTALL XP AGAIN AND UPDATE
Jan 22, 2008 | Acer Aspire 3680 Laptop
Acer Aspire One Netbook 8.9" Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
