Question about Kenmore 73952 Gas Dryer
Poor heat i have a kenmore dryer model c85092 it produces poor heat wondering what the problem could be and also were the fuses are located
    President:
  • 1,136 Answers
Hi, Have you checked the venting to the outside? Is this gas or electric? If it is gas, it could be coils on top the gas valve. I want to help.
Vic
Posted on May 17, 2009
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Kenmore dryer model 970-C85092-00 no heat
element or stats........cheers
Apr 15, 2014 | Dryers
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
My dryer will not produce any heat ? it is only air drying. Is there an element I need to replace or a fuse ?
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts
Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
Dryer turns but we are gettin no heat book said to look for fuses i was wondering where they were located?
On back side of older models885b56b.jpgOn newer models the limits are inside06ad40b.jpgThis video shows how to get into a newer machine
This LINK shows how to get into an older Kenmore dryer
Typical fuses and locations
Aug 16, 2010 | Kenmore Dryers
My 970-c85092 dryer only runs cold air. I'd like
not likely a fuse. check the heating element for a break. the thermal fuse will shut the dryer down completley. could be you need an upgraded thermostat kit for the heater assy.
Oct 04, 2009 | Dryers
Kenmore Dryer model 110.62932100
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Sep 29, 2009 | Kenmore 659 Electric Dryer
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
May 12, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
132 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
