i have a play station 2 slim and i am trying to wire it up to my technika tv and it only has the red and yellow insert in the tv and theres no white in the tv for the sound need help please.
Okay, are you using the original PS2? If you are then it more then likely is the age of the console. The original PS2 console actually can't play some of the games that were made after the PS2 slim was released. If your using the slim than the only thing i can advise is to try using a laser lens cleaner disc and see if that helps :)
I had the same problem. I fixed it by changing system settings, there is somewhere on the console where you can choose between two differant colour options. have a look around and try changing it on the ps itself.
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
I have only seen this when the PS2 slim has been modded. What I do when this happens is hook the PS2 slim to a HD TV. This clears up the color. The modchip seems to drain the video power low enough that the normal TV with composite connection cannot resolve the signal. The only way to repair this is to get a new motherboard that is not modchipped. IF it is not modded, you still need a new motherbaord. Buy a broken will not read discs PS2 slim with that is NTSC or PAL whichever you use. Exchange the motherboards. You also need to be sure the Broken PS2 slim will boot up, and possibly read CD's but not Games.
what type of cable are you using
