Question about Homelite Mighty Lite Lawn Trimmer
How do I take the UT20816 trimmer drive clutch off? Need to replace the spring for the starter cord rewind.
On my trimmer I took the motor off and there was a cable trans. with a silver-colored plate with 3 screws. I took them off and there was the starter cable and the spring (Caution it my pop out on you).
Posted on May 30, 2009
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Replacement of starter cord on HC-150 hedger
You may have wrapped it the wrong way. If not, your spring is either broken, the bend on the end which slides into the plastic has straightened, or the plastic spool has broken where it holds the other bent end of the spring.
Nov 07, 2013 | Echo HC-150 COMMERCIAL SERIES HEDGE...
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
Sep 20, 2012 | Husqvarna 223L
Starter cord has jammed
You will have to remove the starter rewind mechanism and rewind the cord around the pulley, then pre- load a certain amount of tension on the rewind spring.
Apr 17, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Starter cord will not rewind. How do I get to the coil spring? Is the clutch pressed on? Removing the clutch is the only way, I see, to remove the plastic housing. A breakdown would be very helpful.
The starter is on the flywheel side of the engine, not the clutch side. The whole starter mechanism should release from the left side case with the removal of three of four screws. Likely, you will find a broken rewind spring end, or it has slipped from a fastening point on one end or the other. Remove the starter cord to deal with the spring which should have several turns in a CCW direction to pull the cord back into the starter housing. If you need to make a fresh knot in the cord, be sure to melt the end to prevent the knot from pulling out. Hope this helps!
Sep 18, 2010 | Garden
Ryobi SS30 Trimmer. Need to rewind pull cord. I already have the housing off. Need to know the next step in removing clutch assembly.
cut handle off,let spring unwind.remove piece that stops pulley from coming off,then take pulley off,should leave spring intact.dont touch the spring,hell of a job to refit..bolt holding clutch assembly is usually left hand thread.usually two springs holding the two small brake shoes.reasonably easy to go from there
Jul 03, 2010 | Garden
Starter cord broke went to replace cord and spring came out. how do you rewind and reinstall spring and cord. have lots of tools
Best thing to do is replace the starter rope, if you don't, you're asking for trouble. Get the right length of rope, don't use a longer rope than recommended or you could wrap the spring too tight when you start the motor. I always replace the spring too. It's cheaper than trying to wind up the old one and get it back in. Good luck.
Jun 13, 2009 | Garden
First, Im not sure where my air filter is on my troy built. Also, I my starter cord pulled out and wont wind back up. I got down to the clutch and cant figure out how to get the clutch off. What can I do?
airfilter is a square filter over the carburator if the cord is out its not the clutch its in the shroud the recoil sping is broken or needes to be redone what you can do is remove the string from inside shroud turn the coil like you pulling the rope when the spring is tight you can use a c-clamp hold it place reinsert rope & release c-clamp it should rewind
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Strimmer Starter strip
You will need to take the housing off to expose the rewind mechanism. The most likely cause will be a broken rewind spring. Go on the WEB and search for your model and a part list. Locate the spring and order it. Once you install the spring, you will need to pre-tension the spring by by pulling the cord part way out and ciol it on the spool. Good luck
Jan 01, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
157 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
