Question about Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000
Witch way does the teflon side of the seal face the impeller side or motor on a waterway spa pump
  • 59 Answers
The rubber seals around the housing. the teflon goes against the graphite fitting so there is a seal, but it is a mechanical seal.
David
Posted on May 25, 2009
Install new wet end on waterway 4 hp
split wet end from motor take off cover to impeller unscrew impeller screw should be backwards thread hold back of motor with wrench after screw is out turn the impeller off should be regular threads use gloves or put a screw driver in hole to turn dont break the impeller then remove pump from backing plate then reverse to put back together dont forget seals
Jul 22, 2014 | Waterway Pool & Spa
How do you remove the impeller from the motor shaft?
If the shaft seal has been leaking the impeller stem may have split due to corrosion. This makes it very hard to un thread the impeller. After removing the face plate, try sliding a screwdriver into the front of the motor thru the vents. You should be able to seize the armature from turning by doing this. Then use a large channel lock wrench and try and un screw the impeller CCW. If this doesn't work you have to break the impeller off. See my previous post.
Oct 16, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
How do we remove the wety end from the motor?
You have what they call a" Through Bolt" motor. The bolts are located on the back of the motor and run the length of the motor. I believe they are a 5/16 bolt. Just a note..Price a whole pump vs a motor,seals and possibly a impeller first.Sometimes it is cheaper and you get all new parts.
Oct 08, 2010 | Waterway ® 2 Side High Quality 3 Hp Spa...
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
I would like to replace the seal between pump and motor on model# pf-30-2n2c waterway spa pump how do you separate them
Pull the pump's front cover, lock the opposite end of the motor shaft, unthread the impeller, loosen the 4 motor thru-bolts then you can pull the seal plate.
Oct 26, 2009 | Pool & Spa
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
How do you remove the impeller from a Waterway Executive 48 spa pump
Take off the back of the motor, put a wrench on the shaft and turn the impeller by hand to loosen. It may be reverse threaded.
Oct 07, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
PS-1000 Seal
The seal replacement on most pumps requires the capacity to separate the motor from the pump and to dismantle the wet end. Upon dismantling, it will become clear as to where the seal components are to be replaced. The spring half is found in the seal plate and must be knocked out and reinstalled with a properly sized driver and the ceramic seat is attached to impeller. Be careful not to damage the polished surfaces of seal. A light coating of a silicone or teflon based lubricant is most helpful ..
Apr 12, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
Execetive 56 4hp pump
Looking at the face of the pump, the impeller unscrews by turning it counterclockwise. Also, for some strange reason, the 4HP pump gets a 3HP impeller; the rating is embossed, in very small letters, near the center of the impeller. The 3HP impeller part number is: 310-4200.
Be sure to change the seal: US Seal P/n: PS-1000.
Oct 20, 2008 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000 Logo
379 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
