Question about SPARKLE Computer GeForce 6600GT, (128 MB) AGP Graphic Card
Stripy Boot Up
On the boot up screen the card starts showing vertical lines, it then freezes on the windows xp boot up. When i start windows xp in save mode the card has the vertical stripes. I also have an old pc with an agp port with win98seĀ installed where the pc can at least boot up, but only in 16 colors and with the stripes in the background.
I tried reinstalling drivers, switching screens and pc's but it stays the same.
    Problem Solver:
  • 4 Answers
Is it a new graphic card? Sometimes that happens when the graphic card gets overheated and fries up some chips. and sometimes those lines appear when the graphic card has fault in Direct Draw. Try setting your BIOS settings to default. if it doesn't work, i recommend you to take the graphic card to the nearest hardware tech ;)
Posted on Oct 22, 2007
SOURCE:
Emachines t5274 vertical blue lines during startup/XP.
It looks like you've got two issues. If you tried a different monitor and it too have vertical blue lines your video card might be bad, but hold that thought. I'm thinking you need to reload the operating system because you can't boot all the way up which is the second issue.
Have you tried to boot up in Safe Mode and do a System Restore? Turn the computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. When it boots, if it boots successfully things will look different in Safe Mode. The screen will be darker and icons bigger, but that's normal. If you get into the desktop successfully, click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having problems. If the system tells you that you have no restore points, then you will have to either Reload the Operating System or do a System Recovery. By the way, System Restore does not lose your data, documents, music, pictures, videos, or programs unless the program was installed after the restore date. System Recovery LOSES EVERYTHING, it sets your system back to when you first purchased it.
Mar 26, 2012 | eMachines T5274 Desktop PC
My Sony Vaio VGC LA2 shows green lines at startup and after windows processing screen it goes blank. The problem started when it used to hang-up whilst the screen saver came on and the system freezes...
have you tried booting in safe mode?
as the system is booting repeatedly press F8 until a menu appears where you use the aarow keys to select safe mode by pressing enter.
Jan 24, 2011 | Sony Computers & Internet
Laptop screen has vertical lines of garbage 3/4" wide about 3/4" apart. sound system starts making choppy noise after only few minutes powered up. Trying to fix this laptop for a friend - I'm a desktop...
Connect an external monitor to the VGA-output port on the laptop, to see if the video-effects are being caused by the video-card, or by a damaged "internal" LCD screen on the laptop.
Take any genuine Microsoft Windows XP/Vista/7 CD/DVD disk, and "boot" from it. Do the vertical lines appear when booting? If so, you have a hardware problem. If not, then only the currently-installed version of Windows is messing-up your display.
If all else fails, backup all the user's files to an external device, reformat the disk-drive, and reinstall Windows, to see if it's a messed-up version of Windows that is causing the symptoms.
Jul 03, 2010 | Dell Inspiron 9400 Notebook
Computer boots up with many pixel problems
Missing pixels usually mean only one thing the video card is shot and must be replaced. Try to get an older video card (maybe borrow from a friend) to test and make sure it's not the monitor or wiring. If a different video card works and yours keeps failing, a replacement is the only solution short of owning a clean room, robotic arms, a very good grasp on electrical engineering, and fixing that extremely tiny circuitry by yourself.
Apr 18, 2010 | Microsoft Windows XP Professional for PC
They are flashing vertical lines in various colors as well as letters showing
hook an external monitor. if its the same problem, video card is the problem. if it has a clear display, then you need to replace the lcd.
Apr 09, 2010 | Microsoft Windows XP Professional for PC
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Windows XP freezes at startup
Some files can be missing, try to start your computer in SAFE-mode, if it works you can try again, othervise you have to repair you XP-version. Add me david.vk@live.se for more instructions.
Jul 08, 2009 | Microsoft Windows XP Professional SP3 Full...
Windows XP corruption - wifdows, wafdows...
nothing u have to do is just place a windows xp disk and repair your operating system
Feb 11, 2009 | Microsoft Windows XP Professional
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
What's wrong with my computer
Yes. You have a very sick VGA card in your computer. Get it replaced. The reason it runs okay in safe mode is because full potent driver and graphics don't load in safe mode to aggravate the card's illness. When the driver fully loads in normal mode, the card freaks out.
Good luck
Feb 18, 2008 | Televison & Video
SPARKLE Computer GeForce 6600GT, (128 MB) AGP Graphic Card Logo
210 people viewed this question
Top SPARKLE Computer Computers & Internet Experts
Alun Cox
k24674
Are you a SPARKLE Computer Computer and Internet Expert? Answer questions, earn points and help others
