Question about Sony Acid Pro 6 Professional Music Workstation Full Version for PC
Sony acid pro 6.0, microphone level when recording is way high
When i have an instramental playing and i try and record my mic level is out of control high, to where the left & right levels of the mic are maxed in the red, and you can not make out anything. there is no feedback, and if i record on the mic by itself (no other tracks playing) it is fine. I have to lower the instramental sound level to almost nothing to record, then the mic still picks up the instramental. I record with headphones so there is no outside noise for the mic to pick up?????? It used to work properly but does not anymore, did i change a setting maybe by accident????? help please!!!!!
Are u using the volume control or what mixer--u might want 2 try out the volume control--set it up recording
Posted on Jul 16, 2009
The input levels of the left and right microphones are highly inequal, what can I do?
perhaps the left speaker is damaged
what i would do is load a known mp3 too the sdcard
and play it back on your unit
if its aok level wise
then the left mic has an issue
try an external input too the left mic
if it again records bad there is an issue with the input amp and alc circuit
if it records ok chances are the left electret mic has failed and will need replaced out usually these small mics have an amp built in then this output goes at line level to the input switched between line level in mic in or internal mic in as a mix....
Jan 10, 2015 | Yamaha POCKETRAK C24 POCKET RECORDER
Whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Monitoring recording using acid music studio 7
the program doesnt come with that option only pro does
Jun 22, 2009 | Sony Acid Music Studio 7 Full Version for...
Dell dimension4600. microphone does not work. I have a portable microphone connect to the pink mic connection.
it might be a bad mic or it may be your mic settings
its worth looking into, try connecting a audio source to it when you are configuring it and have the volume control for the microphone (on the playback section) so that you can hear it when it starts working
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
Can't get the external wireless mic to record...
This camcorder will record audio from an external STEREO mic plugged into the top connector on the right side of the unit (under the plastic cover). I find it works EXTREMELY well with the various Sony microphones traditionally sold for MD recording (I use a mid-size one: model #ECMMS907). Some microphones may have too low an audio level for these camcorders. Other microphones may not have a stereo plug, but most of the ones that do (and have a high output level) should work You simply plug in the mic. No fussing with settings should be necessary. The camcorder has an onscreen audio meter that can be enabled. I leave it on all the time, so I am sure the external mic is working (mine has an on/off switch as well as an AA battery -- so I really want to make sure!).
Mar 22, 2009 | Canon HV20 HDV Digital Camcorder
Not able to record vocals
Make sure everything is routed correctly in Windows. Double click the speaker icon on your taskbar, go into options, click preferences. You will have the option to view playback or recording settings and levels. Select recording and click OK. This will allow you to select which inputs are active for recording.
If it still doesn't work, make sure you have Acid configured to your sound card. I am not specifically familiar with Acid, but all audio programs need to be configured specifically to the system that they're running on.
Dec 19, 2008 | Sony ACID Pro 5 for PC
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Vista 64 microphone not working
hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
NOW TEST YOUR MIC..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
IF THAT DONT WORK REPLY HERE AND WE WILL HAVE A LOOK AT THE DRIVERS..
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Sony Acid Pro 6 Professional Music Workstation Full Version for PC Logo
796 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
