Question about Frigidaire FEF336BC Electric Kitchen Range
Range unit stands too far away from wall
Just purchased a Frigidaire FEFL67HC range, and the plate at the back of the unit isn't recessed to accommodate the plug and outlet box. Consequently, the unit stands 3-4 inches away from the wall. My old range sat flush with the wall, and I'd like the new one to do the same. I'm tempted to get out the tin snips, but the unit has been in my house about an hour and who wants to cut a hole in the back of a new appliance? Does any Frigidaire unit have a rear design with recess to allow for plug-in and use while still sitting against the wall? Are there any other solutions or parts to order that could fix this?I have same problem with new Frigidiare range. The range open space for the plug-in wall outlet is behind the below oven range drawer. The top of this rear drawer opening is about 3 inches below the 220v
flush mount outlet. I have looked for a 220v recessed outlet box. Arlington and Levitron make ideal recessed boxes but only for 110v.
Any ideas other that tearing up the wall and moving the outlet box?
Thanks.
    Genius:
  • 1,689 Answers
Hi jimruth,
cutting the cage is not an option. frigidaire does have mounting options which was made by 2rd party manufacturer to run compatibility to the appliance. you may want to contact the dealer that sold you the appliance for such options.
does having the exact measurement of your wall where the range will be and get recommendations from the store. another model is also an option.
Hope this helps. should you have other questions please do not hesitate to let me know.
regards,
voodoo
Posted on May 16, 2009
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
Cant find the model number for a maytag gemini double oven with ceramic cooktop. Any advise?
On the Maytag Gemini Series Double Electric Oven, the Model and Serial number is located on a flip-up metal plate/tag which is located on the upper left side/rear of the of the control panel. There is no need to move the stove away from the wall. Simply place your fingers over the top left edge of the control panel and flip the metal plate/tag up from a point just left of the control panel's center and flip it to the left (it's hinged on a screw to the far left of the flip-up plate/tag).
Dec 30, 2012 | Kitchen Ranges
Kenmore digital oven model 79095321303 temperature is wrong. Digital display on oven says 350 degrees but oven thermometer placed in center of oven (middle rack) shows 200 degrees. When I up the...
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • Oct 09, 2011 | Ovens
    I have a GLEF379DQA glass to stove and I want to know how to lift the top to replace the burner.
    1) Unplug unit 2) Remove back plate covering controls on back of oven 3) Notice 2 brackets, 1 on each end holding 2 screws-remove the screws 4) On front remove 3 screws underneath front ledge directly above where oven door closes 5) lift top up about an inch, and pull forward towards front of oven 6) You can now lift it to service - beware wires are still connected - dont pull too far forward and up
    Nov 29, 2010 | Frigidaire GLEF379D Electric Kitchen Range
    How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
    What make and model?
    Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
    Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
    Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
    Frigidaire Gallery ES340 electric range, burners will not turn on
    Okay,
    1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
    Your Range it is electronic control on the Oven but not the Stove Top heating elements.
    After you reset the breaker and it still not work.
    Please let me know more about the unit.
    When you purchase.
    How/when it happen.
    What is the indicator showing.
    nguyen@ite.net
    Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Issues with frigidaire gas range
    Return it. You purchased a "usable" gas range. whether it was on clearance or not is immaterial unless you purchased the unit as a non-working unit. If the personnel in the appliance dept. are not willing to exchange the unit, ask to speak to the manager (store Manager, not appliance dept manager). Explain to the manager that you spent your money for a usable range and the range you received is not usable. If the manager is unwilling to exchange the unit, ask him for his full name and the number to the corporate office of Lowe's. Remember, the unit was already exchanged once, so the story they will try to give you is that they only authorize repairs for non-working units is a lie or you would not have been able to purchase the unit you have. If you cannot get a new unit, do call the corporate office with the name of the store manager, explain you were sold a piece of junk that the store knew had problems and that they informed you were corrected. The problems were not corrected and you would have never purchased the range knowing the problems still existed. stand firm, you will get a new range to replace the one you have
    Feb 09, 2009 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
    Wall oven too hot,at 350 setting is almost 400 degrees burns food
    I have a very old GE wall mount oven. Original to around 1960. You can take the temp control knob off and there is an adjustment on the back of it. Easy peasy and only need a screwdriver.
    Dec 05, 2008 | Frigidaire Kitchen Ranges
    There are mounting plates that recess the plug in the wall. Hardware stores have them in the electrical parts department.
    Apr 15, 2017 | Frigidaire FEF336BC Electric Kitchen Range
    Frigidaire gas range FGF337
    The Frigidaire units have a shutoff valve on the regulator that has to be flipped up so the oven will get gas.
    May 19, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
    Frigidaire FEF336BC Electric Kitchen Range Logo
    104 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
