Question about Kitchen Ranges
After a power outage, my Amana Gas easy touch control 800 touch panel does not work. The stove lights and clicks when I light a burner so it's getting electric yet the pad clock and oven don't work. Any ideas what could be wrong?
  • lisaf282 May 17, 2009
    Yes, I have unplugged it for an hour and I have unplugged it longer nothing seems to reset anything. I was wondering about a fuse?
    Problem Solver:
  • 10 Answers
Has it ever worked since the power outage? Have you tried unplugging it for about an hour and then plugging it back in. Sometimes that can reset the control board and solve your problem. I alway like to try the simplest things first.
Posted on May 17, 2009
  • christravist May 17, 2009
    Unfortunately it sounds like the control panel has gone bad. Most likely due to a power surge during the outage. When the power comes back on in your home like that it can occasionally fry circuit boards on many different household electronics. That's why when the power company turns your power on they always ask you to turn off all your circuit breakers. As for repairing the problem I would see if it is under warranty because usually control panels for appliances are expensive. They are not hard to replace if you were to do it yourself. Just make sure you get the exact replacement panel and take note of where all the wires go before you unplug everything from the old panel.
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Our Amana AGDS902 Gas Kitchen Range is beeping and flashing an F7 error code. We have found solutions for other Amana ranges online, but none of them seem to be for our exact range type. We can stop the...
AMANA – Range/Stove/Oven Fault Codes
Glass link Electronic Range Control (ERC)
F7=Shorted touch panel Verify glass to adapter board connection good, if so, replace glass panel.
Dec 02, 2017 | Amana AGDS902 Gas Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
516 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
