Question about Remington Electric Chain Saw
Unable to tighten chain .. too droopy.
I am a 66 yr old female i do not know how to tighten my elec. chain saw chain it isnt too droopy just a small amount. i tried to tighten the screws where the man at a hardware store showed me but they are already too tight now before i even begin to tighten them.i cannot find the instruction book that came with it. thanks.
There are usually two 7/16" nuts on the side of the chain saw. Loosen those a little first, then turn the screw to tighten the chain - not too tight or you'll stretch out the chain when you use it. Don't forget to re-tighten the two nuts before using the chainsaw.
Posted on May 17, 2009
I cant get my elec worx chainsaw to cut the chain turns but don't cut I'm 71 and a woman so be kind if I'm doing something wrong
If the chain is loose and doesn't snap back into the guide when pulled away, it will have to be tightened. If chain tension is OK, the saw may be waiting for you to put on your work gloves and lean on it to show it who's boss. You can do it!
Oct 23, 2016 | Worx Garden
Chain came off
Take off your chain guard, should be 2 bolts holding the chain bar in place. Then make sure there isnt another bolt or screw you missed, pop off cover put chain on, replace chain guard and tighten chain. It should be that simple
Jul 22, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
Nov 05, 2011 | Electric Chainsaw Sharpener
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
Sep 27, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a Poulan ES 350 and need to know how to put chain back on and tighten.
Start by removing the cover securing nut, remove the side cover,wind the chain adjuster screw at the front of the saw anti clockwise, until the old chain becomes lose, pull the guide bar out and off the adjuster pawl, should now be able to remove the old chain, loop the new chain over the sprocket, and into the guide bar rails, make sure the cutting edge of the chain on the top of the bar is facing away from the saw ( the chain rotates clockwise as you look at it )make sure the bar is still located on the adjuster pawl, re fit the side cover, re fit the securing nut finger tight, now turn the adjuster screw with a flat blade screw driver, until the chain sits snugley in the bar rails, there should be no sagging on the bottom of the bar, now lift the tip of the bar and fully tighten the securing nut, run the saw for a couple of minutes, now re check the tention. The correct tention is so you can lift clear two of the drive teeth out from the top of the bar.
Mar 14, 2011 | Poulan ES350 16" Chain Saw
We have a remote car starter, not sure what brand. We had a new battery installed and now we can't start the car with the remote anymore. We have a 1999 Plymouth Grand Voyager.
Have a remote car starter, new battery, but still will not work. Don't know the brand, believe it to be 9 yrs old and probably no longer in business. 66 yr old female
Jan 31, 2010 | 1999 Plymouth Grand Voyager
I AM FEMALE,HUSBAND DECEASED.I CLEANED MY REMINGTON POLE SAW AND WHEN I PUT THE CHAIN ON ,I MAKE ONE CUT AND THE CHAIN COMES OFF,HELP EMAIL ADDRESS -JIMANDJO@BELLSOUTH.NET THANKS
after reinstalling the chain,make sure the two guide bar bolts are loose, Using a screwdriver,turn adjustment screw to tighten chain to bar. Re-tighten guide bar bolts
Sep 28, 2009 | Remington Polesaw Wizard
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
I need to find the nylon gear that is fused to the steel gear that drives the chain 1625 elec.poulan chainsaw. part name, number and picture.
An IPL for a Poulan 1625 (type 1) can be found here:
http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-1/75.1625-Electric-Saw-Type-1.1.59.1.html
Click the green "Go" tab; Expand the "Illustrated Parts Lists";Click the "Chain Saw Assembly Type 1".
I think you want item 7 ($10.32 & shipping). The nut probably has a left handed thread (tighten it to loosen it). Please let us know if this helped.
Lou
Jul 21, 2009 | Poulan Garden
Remington Electric Chain Saw  Logo
1,058 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
