Question about iLO IWT3206 TV
GREEN PICTURE I have this Ilo IWT3206 that shows green picture the sound is ok and looks good but it is just green withno other color
  • mcretv3 May 16, 2009
    THIS SET IS A DIRECT VEIW NOT A PROJECTION
  • 431 Answers
Hi I am Vortash .. I have to agree with pgh-pa-guy an inspection of the output transistors is a must , but should the they be ok and the tube is suspect .. there is a device we use in the UK called a tube rejuvenating device .. it blows the carbon off the end of the electron guns in the tube and as long as the tube is not too far gone will give it a bit more life .. unfortunately it varies for how long .. but usually long enough for you to get another set .. and I suggest Ebay you can get some good ones on there for a song ... Regards Vortash
Posted on May 18, 2009
    President:
  • 2,992 Answers
Very likely the set has a bad green output transistor. These are sometimes found on the main board and sometimes on the small circuit board plugged onto the end of the picture tube (the neck). It's easy to check the transistors and replace them if faulty. A TV shop could do the repair for far less than the cost of a new 32-inch set.
Posted on May 17, 2009
  • May 19, 2009
    Note to Vortash: You bring back memories of my road and shop tech days. I did many a tube with the tube shooter (as it's sometimes called on this side of the pond). The reason I didn't suggest that as an option was because of the OP description of the trouble. A bad output transistor usually causes the screen to be the solid color. A tube that needs rejuvenation still usually shows all colors, or maybe two if the third is very weak. My money is still on the green output.
    Sniper:
  • 61 Answers
Sounds like one of the tubes is gone. RGB stands for red green blue. These colours are mixed together to make all the other different colours on your tv's picture. when one goes then you end up with whats left working.If tv is fairly old chances are its cheaper to replace then to try getting fixed. tv's have came down drastically in price lately because of such high demand and competition to the market.
Posted on May 16, 2009
  • liamgill6 May 16, 2009
    sorry. Only other thing i can think of is that the scart connection is dodgy. Check this if not solution, sorry i could not be of further help.
ILO DPD4210, no picture or sound. It appears to be stuck in stand by mode. The LED lights are solid Green or Red. It just stopped showing the picture and sound. Any suggestions of what might be the...
Sounds like an ordinary power supply failure. You just have to desolder and semiconductors that are bolted to heat-sinks and or look for electrolytic capacitors that are bulged or not the correct reading. A lightning strike or power surge could have blown a thermistor.
Oct 17, 2013 | iLO 3200 32 in. LCD Television
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My tv is buzzing and wont stop nor will it show picture or sound cant tell if its on or off.
It seems as though the power supply has gone bad. this scan be a easy fix if you are handy. Call ilo and see if they can give you a price on the phone. Be careful though, it might just be cheaper to buy a new set.. good luck
May 04, 2010 | iLO IWT3206 TV
Ilo tv has green tint picture its not hd just regular digital i think problem was caused by a huge speaker i sat near tv
I have done this before. The speaker caused your green tint. The only way I was able to fix mine was with a magnet. I was able to get the green to the bottom corner of the screen. But be fair warned using a magnet can also make it worse to. The best thing to do is bring it to a repair shop and have them fix it for you.
Jul 05, 2009 | iLO IWT3206 TV
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
JVC AV-28WT2EN picture has too much green
go into service mode by pressing mute and i button at once on your remote, choose option 2, change green setting by pressing 6 button until color looks natural,save by pressing ok button and leave service mode by pressing i button.
good luck
knut
Mar 13, 2009 | JVC Televison & Video
ILO TV
call a tech as your tv is repairable i cannot recommend a tech for you due to my location belize good the tv is having problem in the color circuit good luck
Apr 05, 2007 | iLO 2600 Television
iLO IWT3206 TV Logo
128 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
