Question about Saeco Vienna De Luxe Espresso Machine
Water leaking on counter and less than half a cup of coffee.
Saeco vienna automatica refurbished machine.  my husband just took it apart and it looks like calcium build up on a mental box,  i am assuming that that is the boiler.  can we buy a boiler so he can install.  i called the only place in the toledo, ohio area and they never heard of this brand. ugh!  thanks!! cynthia
  • 487 Answers
Oh yeah you can buy the about anywhere on line.
http://www.cerinicoffee.com/Saeco_replacement_parts.asp
Posted on Apr 16, 2008
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
Only half of a cup of coffee dispensed from Saeco Vienna
the trouble is the pipe that goes to the water tank follow it its hook to a white plastic sensor go in that piece and come out that the level sensor that broken that the first thing and most likely broken if not the circuit board
Apr 04, 2009 | Saeco Magic De Luxe Espresso Machine
I have a Saeco Vienna Deluxe Model. We have been experiencing water leaking from the machine. It leaks under the tank and floods the counter or leaks into the spent coffee disposal bin. I removed and...
If it leaks under the water tank then you have to replace the gasket in the machine where the water tank inlet are.
If you have a leek inside the door, make sure the hole behind the brewing unit (in the chassis) are clean.
That you get a half cup of coffee one time and a full next time can be the electric board in the machine but can also be the flow meter.
Hope this can help you.
Best regards
/Mirran
Aug 25, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco coffe maker doesn't work
Thank you for your concern! I drove it over to place nearby that fixes these machines in Los Angeles. That way, I can avoid costly shipping charges!
May 24, 2008 | Saeco Vienna Digital Coffee Maker,...
Can't make coffee
Try to open the steam knob and make a cup of water.
Dec 30, 2007 | Saeco Vienna SuperAutomatica Coffee...
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
113 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
