Question about Frigidaire FWSB5700DS Top Load Washer
Washing machine won't drain
I have a frigidaire machine (not sure what model) it won't do anything after it fills up. I would think its the pressure switch but cant be sure. Is there a way to by past the switch so it goes on? Rather not spend money on parts if I'm not 100% thats the problem.
thanks
  • simonvigneau May 16, 2009
    Now its not doing anything, just get a hummm sound from the motor.
    Scholar:
  • 85 Answers
If it stops filling but doesn;t run it is your lid switch. if it runs but no agitation or spin it is the belt.
Posted on May 16, 2009
  • shinn8
    shinn8 May 17, 2009
    If it is humming then check your belt. if belt is ok then you likely have a transmission problem which is likely fatal
Washer won't fill with water
Hi Allen, this is JK. I see that you are having trouble with your washer (FEX831CS) not spinning or filling with water. For the washer not spinning, check the drain hose length and make sure there are no restrictions. The concern could be with the timer or the drain pump. For the washer not filling, I would check the water pressure, pressure switch and the water inlet valve. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Already took off pump & cleared out $12 in change but still will not pump all water out or spin out. can hear pump running but think the damage has already been done. would it be pump or pressure...
If the washing machine won't fill up, make sure that the water supply valves are turned on. Next, make sure there are no kinks in the supply hoses that run from the supply valves to the washing machine. If nothing is obstructing the hoses, you may have another controls issue.
Several of the washing machine controls are also responsible for the washing machine not draining, continuing to fill or filling too slowly. If the washer doesn't want to drain or stop filling, the issue could be the pressure switch. When water enters the machine, water also fills a tube in the pressure switch. When the air pressure reaches a certain point, it triggers a switch that will stop the machine from filling. Locate this pressure switch on your machine and look for damage. If you have a multimeter, use it to find any electrical issues. If there is no reading, the pressure switch needs to be replaced.
Read more: Tips to Repair a Washing Machine ' eHow.com http://www.ehow.com/way_5435622_tips-repair-washing-machine.html#ixzz1C6BhALK0
Jan 25, 2011 | Frigidaire GLTF2940ES Front Load Washer
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FWSB5700DS Top Load Washer Logo
150 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
