Question about OKI Office Equipment & Supplies
OKI C3100 - Unable to reset the drum life counters
Hi, I would like to reset the Drum Life counters on my OKI C3100 - there are heaps of instructions for the later OKI models with LCD Display - the C3100 does not have an LCD dislay on the front - Any Ideas?
  • chris757 May 17, 2009
    I can only view the usage settings - there's no way to reset the counters through the software
  • jenrice35 May 11, 2010
    Can you access the menus through the Oki software installed on your computer? The manual http://www.okic3100.co.uk/library/docume... indicates that you can access the menu by selecting "START" - "ALL PROGRAMS" Unfortunately I have the C5150 that has the LCD menu and Networking which both allow you to reset.
  • 413 Answers
SOURCE: How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
Posted on May 07, 2009
  • 1126 Answers
SOURCE: OKI c5100 flashing "K drum life" across screen. what does this mean?
"K" drum refers to Black drum Apparently the black drum has reached its life expectancy and needs to be replaced.
Posted on Jun 07, 2009
  • 526 Answers
SOURCE: Reset the drum counter on Brother MFC-9840CDW
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Posted on Jun 27, 2009
pineworks
  • 4041 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
  • 97 Answers
SOURCE: OKI C6100 has the following error when printer is
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Posted on Mar 29, 2010
Msg says Drum Unit Life Order K Toner but my K Toner is at 90%.
The drum may have an electronic counter installed and after so many pages being printed, even though it is still good, it will determine that it is time to replace. You may be able to replace the electronic counter. If not, you will need to replace the drum.
Jul 03, 2014 | Oki Brand Oki C530dn Laser Printer Duplex...
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
How do I reset the counters for drum life?
You must order a fuse from a toner supply company.
Ask for instructions but it is not a easy task. I pay someone to do mine.
Feb 17, 2010 | OKI C5500n Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
press ok,
Jun 27, 2009 | Brother MFC-9840CDW Laser Printer
Oki C5450 error message
The figure after the K drum Life tells you how much life there is left on the BLACK (K) drum. C indicates Cyan, M indicates Magenta and Y indicates Yellow.
Go to the USAGE MENU and look at the K DRUM LIFE setting. This will be a 2 digit percentage value. As you have just seen the message appear this will mean that the drum life remaining is ....whatever the 2 digit value displays.
The life expectancy of a drum is approximately 15,000 pages.
Jun 08, 2009 | OKI C5400 Laser Printer
American English
May 06, 2009 | OKI B4250n Laser Printer
Apr 18, 2009 | Office Equipment & Supplies
I would like to reset the drum counter of my OKI 8800
You need to insert a 1/16A fuse into the drum and let printer blow it thus resetting the counter. Don't use fuses with the higher rate - they can easily blow your printer instead! Much more expencive that putchasing a new drum. By the way - 20k at continuous printing, meaning print jobs are as big as 100-200 pages each. The less pages per job the sooned drum life ends up.,
Mar 05, 2009 | OKI C8800dn Led Printer
Message on printer
Your printer has counter on it that keeps track of the number pages that have been printed with it. It is warning you that the drum unit is coming close to the end of it's rated life. Order a black drum unit and have it on hand. Some time in the near future the printer will stop operating until you install the new drum which will come with instructions on how to install it. If you order it now, you will avert a "Crisis" later. Ed
May 22, 2007 | OKIDATA B4350N LASERPR 23PPM ETH-W/ PS BLK...
1,669 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
