Question about AOpen MX4GR (91.89Y10.102) Motherboard
Black Sceeen Only
My Pc Won't boot the fans are on, the memorys is good, the power suppy is good, the motherboards little leds are on so i know its getting power, but there Beep, and no Bios. Only a  Black Screen. I added a good video card from my other pc to see if it would solve the problem but it didn't, do you have any idea how i could fix this problem.
  • Bonko Oct 16, 2007
    I think I know what the problem is I need 233mh ram and not 400mhs RAM I wil see if this solves anything
Renew the video card
Posted on Feb 12, 2008
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
Mar 26, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
May 01, 2017 | HP Pavilion dv5020us Notebook
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Jan 08, 2011 | Biostar TF7100P-M7 Motherboard
Green light next to power button stays on - no response from computer, totally frozen for up to 12 hrs, then green light goes off, computer suddenly comes on for 5-10 min then freezes again.
Good day sir, hi, You need a thorough check on your PC.
But first try testing the Motherboard, Processor and Memory module.
As this point you need a friend, that knows how to tinker with your PC
Or you may need to do this.
1. memory testing:
Try replacing a new memory ram module on your PC, get the modules out of the memory slot, and let it be tested on another PC. if good,
2. power supply
Test for the power supply box, remove the 20/24 pin power connector from the mainboard and short the green and any black wire, your fan should blow out air.
3. Test for motherboard.
remove all coonections from the motherboard, except the 20/24 pin power connector, and the 12v 4-pin molex power connector, connect the pc speaker or the thumb speaker on the speaker port, connect a keyboard, clear the CMOS, (or remove the battery temporarily), connect the header panel (power switch, reset, power led) place the processor and memory (the tested good one). power on.
You should hear a beep (good) The keyboard will light up the three leds, then a few seconds, the numlock led.
If you hear 1 long and 2 or 3 short beeps, problem with the display section. Reseat any graphics card. test again.
If you hear continous beeps, reseat the memory, if the beeping persist, replace your motherboard.
If you hear nothing? only fan blowing, replace your motherboard.
I can only give you instructions, you need a someone who knows how to service a PC.
Dec 17, 2009 | Compaq Presario 5000 PC Desktop
Motherboard no responce
When you turn on the PC, normally the boot codes start at 00 and go up to FF (ex 00, 01, 02 etc..).
1.remove the ram memory and video cards if any .. 2. check and reconnect the power suppy wires for mother board , 3. dont worry about your operating system data is lost . 4. if u have not heard any beeps while booting then could be the ic chip ...reseat it properly and make sure it is properly locked . 5. check the fan ...the chip can will over heat when the fan malfunctions ..
this should help ...based on info provided by u , provided u take atmost care while opening or reseating the mobo items
good luck..!
Oct 26, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Jul 13, 2009 | Intel D845GVSR Motherboard
Not everything powers up when I turn on my disassembled computer
remove first the power suppy. if it is 24pin power suppy, shorten pin 15/16. that is the black and green,
if the fan of power supply rotates, then the P.S. is ok.
then return it to motherboard. check your connection with the motherboard power switch.
good luck
Feb 14, 2009 | Jetway (939AGP-OC) Motherboard
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
Tried to turn it on, no powr. Replaced the power supply, little led on the mother board, but no power, no fans.
no beeps.
I tried 3 different power supplies.
I stripped out the memory and hard drive and put it in the dumpster where it belonged.
Jun 09, 2008 | E-Machines T2240 PC Desktop
Need drivers
To download drivers for the EliteGroup 7S5A Pro , click on the link below.
Most common issue's for not being able to boot PC system.
1. Swap power cord/replace. Check video connection cable,
Check monitor power cable. (Check wall outlet is good).
2. Reset cmos/bios. (Need to use manual for board to reset)
3. (No display on monitor, can hear fan's running & LED's on case light/flash). Remove & re-seat video card, same for memory. (While in PC check all power connections & data cables to devices.
4. Fans not running & no LEDs do not light/flash. Power supply may be bad.
May 01, 2008 | EliteGroup K7S5A Pro Motherboard
AOpen MX4GR (91.89Y10.102) Motherboard Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
