Question about Sony Audio Players & Recorders
Surround sound not playing TV audio
Surround sound system not playing TV sound. The tv is a NEC flatscreen not sure of the product name. The surround sound is a Sony HTSF2300. I run my cogeco cable through a dvd player. My yellow, red and white chords are connected through the tv and dvd player. I purchased a dynex digital audio cable that I connected to my dvd player and receiver to get the sound from the tv. The sound from the tv will still not play through the surround sound. Is there a special combination of settings I need to do or is there another product I must purchase?
  • Sony Master
  • 2,045 Answers
White and red cables are for stereo (left and right channels). If you need a surround you'd have to connect using different sound ports
Posted on May 02, 2017
    Master:
  • 604 Answers
You need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
  • 47 Answers
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
SOURCE: Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Posted on Jul 24, 2008
SOURCE: ihavea 37'' dynex lcd and want to hook up a samsung home theater
cable box needs to be dolby digital to allow surround sound to work
Posted on Jan 11, 2009
  • 1044 Answers
SOURCE: No surround sound coming from tv. surround sound
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Posted on Dec 20, 2009
techman007
  • 1112 Answers
SOURCE: How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Posted on Dec 21, 2009
Got a sony to and surround sound system works fine but when I want to screen mirror my phone to tv I have to turn surround sound system of to get volume? Please help
Assuming that the TV is the device that is recognizing the phone you may have to route your spdif (optical out) via optical cable to the back of your surround amplifier as a separate input to the surround system. You'll be able to select this audio through the surround receivers remote. Just note what the Optical input was named on the back of the surround receiver. The reason you have to do this is that the 'Smart' Tv is what is recognizing the phone's bluetooth or DLNA address so the video and audio are going to the tv. The only way the surround can play the audio is via the TV's optical output. Optical cables are really cheap on Amazon.com. This one is $6 and will work flawlessly if the surround receiver is less than 6 feet away. http://www.amazon.com/AmazonBasics-Digital-Optical-Audio-Toslink/dp/B001TH7GSW/ref=sr_1_1?ie=UTF8&qid=1425292532&sr=8-1&keywords=Spdif+cable
Mar 01, 2015 | Sony Audio Players & Recorders
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Getting tv in surround
you need to plug rca cables into the audio out of your tv providing it has them then go to the setting menu in the tv go into the sound options and turn on surround sound
Jul 01, 2010 | Curtis DVD5091 Theater System
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Have surround sound only when play dvd..
if you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
Jun 26, 2009 | Philips SoundBar DVD Home Theater with...
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Jan 06, 2008 | NexxTech ESDVD100 System
No sound
I suppose you have a surround sound system that is now not functioning? They must have disconnected your audio out cables from your television to your surround sound system. Make sure your main audio out channel on your television is connected to AV1 in on your surround sound system. It is probably an RCA cable (red and white). Then when you play your TV, make sure the audio is set on AV1 for your surround sound system by pressing the function button until AV1 is on the display. Let me know if this helps.
Dec 26, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
127 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
