I have a karcher high pressure washer model hd 2500 hk. What would make my unit stop running after about 45 seconds ,running at full throttle and at high pressure
There could be two possible causes for your problem, one is oil level in the engine could be low, or the engine is tilted or not positioned on a level ground, and the second one is water in the carburetor. Check the oil level and replace the oil if necessary, drain the fuel from the fuel tank and the carburetor and clean the carburetor ports and jets, check the fuel for contamination, check and replace or clean the spark plug if necessary, check if the air filter is blocked, dirty, carbonated, or saturated with oil, and replace if necessary.
