Question about HP DeskJet 6840 InkJet Printer
HP printer doesn't work after clearing a paper jam
Deskjet 6840 printer does not work after clearing a paper jam. I was using a card stock when it jammed, and cleared it from the FRONT of the printer. I read later that clearing from the front can cause harm to printer. I went back and forth with HP via email and all they had me do was try to print using the front panel buttons. They also had me run through some steps to reset the printer. They gave up when I let them know that I could not print a test page. They said nothing about getting into the back and messing with the rollers and gears.
    Champion:
  • 214 Answers
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it. What have you got to loose?
Posted on May 16, 2009
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Can i make copies of a paper
Hello.
If you have a HP DeskJet 6840 then you won't be able to make copies since it doesn't have a built-in scanner. You can buy a scanner separately, scan the document using the scanner and then print it using the HP.
Apr 05, 2010 | HP DeskJet 6840 InkJet Printer
Says paper jam but there isn't one. Have done all the troubleshooting steps..I do mean all of them. how do I get the paper jam status off my little hp deskjet 3845
I ran into a similar problem on another HP Laserjet Printer so this is what I found out from some tough researching. There is a step that requires a specialized tool which is inserted into the printer to clear the problem. This may be caused by an internal (no diagrams available) optical sensor that somehow gets covered with paper dust or blowback (ink particles blown backwards into the printer)? This tool may clear the problem, which I've heard is similar to a strip of heavy card stock. I have not found the procedure for this just that someone mentioned the same problem. Last resort is taking in the stupid printer to be serviced. Hopefully an HP tech will come forward and describe the procedure and maybe some maintenance diagrams. Good Luck.
Jan 26, 2010 | HP Deskjet 3845 InkJet Printer
Envelope jam
Tweezers. There could still be some small piece of paper under a sensor somewhere. Get a torch and dive in! Pull it apart Nothing to loose
Apr 06, 2009 | HP DeskJet 6840 InkJet Printer
I had a paper jam, and now every time i try to print it jams the ink cartrages , one paper jam and now it will not work
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 28, 2009 | HP Deskjet 5440 InkJet Photo Printer
Paper Jam when there is no paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 21, 2009 | HP DeskJet 9800 InkJet Printer
Paper Jam
Jan 11, 2009 | HP DeskJet 5550 InkJet Printer
1: the paper jams when it tries to print
Jan 11, 2009 | HP DeskJet 712c InkJet Printer
I need help repairing my HP Deskjet 5110xi all-in-one
Jan 10, 2009 | HP OfficeJet 5110 All-In-One InkJet...
Hp deskjet f380 paper jam
Jan 07, 2009 | HP DeskJet F380 All-In-One Printer
HP DeskJet 6840 InkJet Printer Logo
209 people viewed this question
Seeker5211
Seeker5211
