Question about NetGear WG111 802.11g/b Wireless Adapter
Wireless connection from mac book to netgear router wrn2000 drops
Just installed netgear WRN2000. I have a pc laptop and a macbook. The pc is fine but the macbook keeps loosing connection.
  • 33 Answers
I have the same problem and have read numerous articles on the same thing, it seems that MAC is having a problem with some of the aircards they put in the macbooks and should have a fix out soon.
Posted on May 26, 2009
Keeps dropping signal to iPhone & computer
Hello!
I am not able to locate a model 67, so I presume that is short name for it.
Can you look at the label on the bottom and get the full model name? Examples of Netgear model names are WRN2000.
As for the signal dropping, it is possible that the router needs a firmware update. I would suggest searching for a firmware download for the modal have.
Jul 01, 2014 | NetGear Computers & Internet
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
I have an old mac book running mac 10.3.9 My router is the WNR 1000 My Mac sees the router but when I try to connect it says, "There was an error joining the AirPort network "NETGEAR-2" I...
try changing the security type in the router, the old macbook might not like the type of security you are currently using. This resolved one for me changing it from wep to wpa-psk
May 20, 2011 | NetGear WNR1000 RangeMax 150 Wireless...
My wireless router isnt working. I have a NETGEAR Wireless-n 300 Router with the label WRN2000. Is this a strong router and can I get a stronger one that produces the capability to use more wireless...
That is a good router.
Is your wireless device (iPad? laptop? notebook?) using a Wireless-N adapter?
If not, all you get is the much-slower "Wireless-G" speed.
Measure, measure, measure.
If you use an Ethernet cable to connect from your computer to your router, do you get a much-faster connection?
How far (and how many walls) between your router and your computer?
Dec 14, 2010 | NetGear WNR2000 Wireless Router
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
Internet connection frequently drops netgear wrn2000
Hi
If the Internet connection frequently drops, It could be wired or wireless.
If it is wired connection u can try the following troubleshooting steps
1) connect Modem-Router-Computer
2) Open router UI (www.routerlogin.net)
3) User name : admin , Password: password
4) on the left hand side in the blue panel select WAN setup & reduce the MTU to 1400 & click apply.
if the problem still continues upgrade the firmware of the router.
This should resolve the problem
NOW IF THE WIRELESS CONNECTION DROPS, try the following troubleshooting steps
4) on the left hand side in the blue panel select Wireless settings (under Setup)
5) SSID: (user defined)
Channnel : 11 or 6
mode : upto 54 mbps or 150 mbps
Security : WPA-PSK (TKIP)
PASSPHRASE : (user defined)
Click apply
This should resolve the problem.
Thanks
Vineet Bajaj
Sr. Tech support Engg.
NETGEAR
Jan 11, 2010 | NetGear WNR2000 Wireless Router
Macbook will not connect to wireless connection.
Try to use NetSpot app (it is free) http://www.netspotapp.com/
May 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook 13.3" won't log in to wireless
You need to check your network card software your problem may lay there. I've seen this problem many times in the passed. I will install a wireless network card or software on someones computer and two days later it will not connect everything looks fine. No matter what I do it will not connect. Remove net software for the card or on board wireless reinstall and boom it works fine.
routers may need reset or configured off the internet or the start up cd. I take this a wireless router hooked to internet gateway. don't know not enough information you may need to tell me a little more. first try install of net-card software then set you working router to unsecure no pass word need see if you connect then change it to you wpa password protected.
Mar 20, 2009 | Apple aluminum 13-inch MacBook laptop-...
Connecting mas os x
seek info here or contact support.
http://kbserver.netgear.com/inquira/default.asp
you may need to use a mac address.
Oct 17, 2008 | NetGear WGT624 Wireless Router
NETGEAR WRN 2000 - WG111 keeps scanning
i try to dowload the driver for a wireless usb adapter wg111t only one i see his detective one
Oct 07, 2008 | NetGear WG111 802.11g/b Wireless Adapter
NetGear WG111 802.11g/b Wireless Adapter Logo
676 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
