Question about IBM ThinkPad T40 2373 Notebook
IBM ThinkPad Laptop Sound Fades Out & is Low ... Until Restart
Over the past few weeks, even turning the computer volume up to maximum, the sound will still be too low to be intelligible. Or I'll start out turning it up maybe halfway, then over a few minutes/hours/days I'll turn it up full blast b/c it'll have lessened again. Restarting fixes the problem for a while, til it does it again.
Sound quality used to be excellent, and it was almost *never* necessary to turn it up full blast -- that would typically be too much to handle. Now, that's the only way I can generally hear any sound. I don't have any external speakers any more to hook the laptop up to, nor do I have headphones.
I have no ? or ! in my Device Manager, and all drivers are installed and up to date -- I just checked again today. Do I need a new sound card...? If so, how can you tell when it's that?
Thanks for your help!
  • lionessthere Jun 25, 2009
    No. As I said, "Restarting fixes the problem for a while, til it does it again."
    However, restarting is not a "fix" -- it's a bandaid over the problem that still will recur. Anyhow, I just need a new darn computer -- I have a couple of issues with this one.
I think i know how worked for me but dont kow if it will work for ok first you push and hold the power button untill all the lights turn off then wait like a min and turn back on and your done it worked for me.
hope it helped you if it did just say thx if you want
Posted on Jun 25, 2009
IBM Thinkpad T60 suddenly has very, very, very low sound. Any sound is heard at extremely low volume from both speakers and from headset 1/8" jack! Checked volume in control panel and all other...
open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Aug 05, 2011 | Computers & Internet
Very weak sound from ibm t42 thinkpad - internal and exteranl speakers
There are two ways to set the sound on an IBM thinkpad, hardware and software.
Hardware sound can be set via the speaker buttons below the screen. There should be three buttons: Mute, Volume Down, and Volume Up.
Software sound can be set in windows through the speaker icon on the bottom right of the screen. Click on the icon, and drag the slider up or down to change the volume.
If you don't have the correct drivers installed, these two settings are separate (e.g. It is possible to have the hardware volume down low, and the software volume set really high, and still have music playing relatively quietly). I would suggest turning both of them up and see if the sound gets louder.
Mar 07, 2011 | IBM ThinkPad T42 Notebook
Thinkpad T41 with XP-sp3: No sound / working fine until yesterday
Hi. Try plugging in an external speaker just to test the issue. It could be just the speaker of the laptop is having the problem. If you were able to hear the sound from the external speaker then the problem is the built in speaker of the computer. If there is no sound coming out to external speakers. Try to reinstall the driver of your soundcard.
Jun 17, 2010 | IBM ThinkPad T41 Notebook
My laptop has no sound from either the built in speakers or if I use headphones. I have turned every volume control I can find to maximum but to no avail. Help! Pablo
Go into the Device Manager, uninstall the sound card, reboot.
Hopefully that's all you'll have to do.
Let me know if that works.
Apr 04, 2010 | IBM ThinkPad T40 2373 Notebook
Very low volume output even with the volume turn all the way up. I connected the system to different computers and came up with the same problem. The volume on the computer is also turn all the way up and...
I had the same problem and found the root cause to be the RF speaker connector at the back of the subwoofer. The male and female connectors are OK. It is the 5 male pins inside the connector and the way they connect to the female holes that is the problem. Wiggle the RF speker connector as you move it in and out until you get 100% of audio voilume back. Once you get it back, do not move the connector. Have not found a permanent solution to date beyond this.
Jan 08, 2010 | Dell ADA745 Computer Speakers
Can not hear sound
The thinkpads have a sound key on the keyboard. usually operated by holding down the FN key and pressing the key with the (think its blue) speaker symbol on it. Make sure this is on and the volume is turned up.
Also check that the volume under the Sound option in control panel is on.
If these are suggest obtaining latest sound drivers from IBM web site and reinstalling them.
Nov 05, 2008 | IBM ThinkPad R52 Notebook
IBM THINKPAD T42 sound problem
FN pg up pg up. It that is not it try settings> control panel> sounds and multimedia> audio> volume Make sure the volume control and wave sliders are a least past the halfway point. Also check that the mute box is empty. If that dose not work then in that same window try > Advanced and make sure those settings are correct.
Sep 10, 2008 | IBM ThinkPad 600X Notebook
No sound
Start with this.....................
  • double click the sound icon located down the right corner of your display.
  • uncheck the option if any is muted.
  • slide all the volume/options to the top.
If the above options yield nothing try this........................
  • uninstall the sound device at the control panel.
  • restart the computer.
  • you will be asked to install a new found hardware, click next till to the end.
See the results, if fail too try this..........................
Let me know if all those worked or not.
Jan 20, 2008 | IBM ThinkPad T40 2373 Notebook
Microphone Feedback
Turn the volume down, even if it's off.
The laptop picks up on anything near it, not necessarily audible sound.
Dec 05, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T40 2373 Notebook Logo
388 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
