Question about Husqvarna Garden
My husqvarna W4815 comercial 48" walk behind mower's left wheel stopped pulling. I have recently had the drive belts replaced, so I pulled the left pulley assembly off, cleaned the pulley's with a wire brush, reassembled without improvement. We can rule out the transmission, however there is a little play in the drive shaft bearing but not enough to make it quit pulling. I have adjusted the left steering shaft to the end of the adjustment;no help.
  • 10865 Answers
SOURCE: hydrostatic cooling fan belt adjustment
If the belt is loose it may simply be worn out and need to be replaced. Look carefully to be sure that the belt didn't come off one of the pulley wheels as this might give it the appearance of being loose.
The way the belt tightener is engineered, there is no tightening to it, just spring tension. Get back and let me know where it is at. I know I can assist you in gettting to the bottom of this problem.
Posted on May 20, 2009
mowerman1857
  • 389 Answers
SOURCE: Craftsman rotary mower, p/n 917.374821 will not move sometimes.
It is quite possible that one or the other of your pinions (item 55 in parts manual) has gone bad in addition to the wheels. Start the mower, engage the drive and lift the back end just enough to clear the ground and see if both wheels turn. If only one wheel turns, attempt to stop it from turning by setting it on the ground at an angle, if the opposite wheel does not turn, you will need to inspect the pinions.
Posted on Oct 30, 2009
  • 420 Answers
SOURCE: MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Posted on Jun 04, 2010
mikehowy
  • 177 Answers
SOURCE: Yard Machines 22'' mower, pull cord won't extend
is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Posted on Jun 07, 2010
vetteman3002
  • 2299 Answers
SOURCE: I HAVE A TORO SP
It sounds like the cable still needs more adjustment. The cable needs to be tighter. This is going to be hard to explain by typing. But I will give it a try. When you pull the handle in about 1/2 way mark the place where the lever on the drive motor is at. And take the cable loose and reattach the cable back to the mark that you made previously. So when the bar is released, it is like it is pulled in half way now. I hope that this makes sense. Let me know if I need to try to explain more.
Posted on Nov 12, 2010
Size of drive belt for HU700F walk-behind mower
belt lengths are printed on the back of the belt
so if it reads as an example 645 that will be the length so if you want one that is 1" shorter then the belt reading will be 644
if it is in mm the 1" shorter will be 25 mm shorter than the printed number
Sep 01, 2016 | Husqvarna HU700FH 22-in Self-Propelled...
How to tighten drive belt on 26 inch walk behind mower or replace drive belt
Here is a video about how to replace the drive belt on a walk behind mower, hope it helps you out!
How to Replace Lawn Mowers Drive Belt
Jul 28, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Why isn't Lawnboy lawn mower model NO. 10604 drive not working
Inspect the pulley where the belt loops on the wheel transmission. There is a tension spring, that when you pull the level, it puts tension on the belt. If that spring is missing or the pulley does not provide tension the wheels will not turn because the transmission is not being engaed..
May 23, 2014 | Heavy Machinery
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
Where is the free-wheel control lever on husqvarna cth173
Sitting on the cth173 it is behind the right hand back wheel.Get off mower look at wheel an 9 oclock, Between treads of tire and mudgard you will see a wire. It pulls in and out'Good luck
Sep 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When trying to turn left there is a clicking sound and the wheel turns but with difficulty. I checked below and did not find any abnormalities.
Have someone walk beside you while you drive. He maybe able to locate the problem. It could be a belt rubbing on something. Good luck.
Jun 20, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My huskvana wht 3615 walk behind mower constantly pulls to the right how do i fix this
The right wheel shaft may have slipped its pin, allowing the left wheel to provide more power. I had a similar problem with a DR Mower. Farmerbear at FixYa.com
Sep 29, 2010 | Husqvarna 36" Wh3615 Walk Behind Mower...
Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
238 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
