Question about Hobart AM14-253 Free-standing Dishwasher
Leaking at bolts at drain
Have a leak at the drain around the bolts.
You must change the gasket between bottom flange and machines underside and apply Hobart mastic to each bolts, not expensive but may require some plumbing dismanteling
Posted on Apr 21, 2008
What can I look for if transmission oil is leaking in pathfinder 1999
pink coolant --- oil cooler in radiator leaking into radiator
pink oil marks on ground under vehicle
Dec 17, 2017 | 1999 Nissan Pathfinder
I have oil around the area where my drain plug is but it istn coming from the drain plug and there isnt alot just a bit whats up with my truck?! I hope yall can help.
Could be the gasket for the whole oil pan that's leaking. That would let oil run down the oil pan, to where the drain plug is.
Feb 06, 2011 | Ford Ranger Cars & Trucks
Leaking oil from reart diff
Where is it leaking from? Around the edges of the cover?
You may need to make a new gasket for it.
Drain oil by remove lower bolts and slightly prying on cover so fluid starts draining.
Slowly make your way up to the top bolts until it's completely empty.
Remove cover, clean old gasket off housing and cover.
Attain gasket maker from any auto store, and spread a even amount around edge of housing, where the cover and housing touch..
Replace cover, fill with oil, and see if this stops the leaking. If not, you may have just rusted out the cover, after years of wear and rust (depending on the year of the vehicle) and may need to simply replace the cover.
Only major problem is it would be leaking from the side or where the drive shaft enters the housing, which would require new seals, and a bit more work!
I hope this helps!
Jan 11, 2011 | Toyota Land Cruiser Cars & Trucks
My water heater is leaking cold water from the bottom. How do I fix it? its a Richmond miser. Model # 8v30-1
First shut off power then remove acess cover and carefully move insulation out of the way so you can see around elements.Check to see if leak is coming from around element.If it is determine what type of element you have. Either screw in or bolted in. Both have thick rubber gaskets that can be replaced by draing water heater and removing element then install new gasket and reinstall element.
To drain heater shut off valve on incoming cold water supply line ,make sure electric power is off. Connect drain hose to drain valve and put other end to floor drain or sump basin.You can open faucet on hot side near by to prevent vacumn and drain. If you have screw in type disconnect wires,marking them for reattachment,then use large open end wrench or pipe wrench on hex section of element and turn to left to remove. If you have bolt in element spray bolts with wd-40 or similar and carefully loosen bolts then disconnect wires and remove element.install new gasket and reverse to reinstall. I would recommend that you replace elements at this time if you are sure this was the source of the leak.
If you don't think it's leaking around elements then check fitting on both water lines to water heater to be sure they are not leaking and seeping down thru insulation and leaking out of the bottom of heater. Next check around drain valve for leak and if it's leaking you can try tightening it a little or replace it with 3/4 x2 brass nipple and 3/4 inch female iron pipe boiler drain. Use teflon tape or pipe joint compound on all threaded connections.
After you have eliminated all other sources for leak then it is probably the tank itself. If it is less then six years old the tank should still be covered under warrenty. Most warrenties will give you a new heater but installation will not be covered unless you have extended service coverage.
I hope this helps you some. Thank you
Dec 27, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
Leakingfrombottom
Are you sure that it is leaking from the bottom and not around drain connection or mounting flange at bottom of sink. If it leaking around drain line you can try tightening hex head bolt that hold drain line to disposal. Also if that is where it's leaking and you cant stop it you can get a replacement gasket from hardware store. If it's leaking around mounting flange you can try tightening three slot headed bolts and see if that helps. There is also a gasket that fits between tiangular shaped mounting flange and bottom of sink that is replaceable. If it is actually leaking from the bottom of disposal then you will need to replace the disposal. hope this helps. Thanks
Nov 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you change the transmission filter in a 1997 jeep loredo
If you have a pan drain plug, drain the pan. If not, remove all bolts around it's perimeter, leaving two on one edge loose but not removed. Use a large catch pan or I've seen some people use a garbage pail cover over a smaller pan with holes drilled in the center of the cover so it drains.
Remove the filter, making note of the position of the filter and screw length (if any screws are longer or shorter they must go back in the same holes)
Remove ALL gasket material from the pan and rail, clean the pan and magnet.
Reverse process to assemble. Pan bolt torque is around 14 inch pounds.
You don't need a torque wrench if you use a 1/4 inch ratchet and do not pull down hard when tightening. DO NOT crush the gasket so tight it bulges out. Install all bolts by hand before tightening, tighten in a cross pattern, not around in a circle. Re fill with the proper fluid, run the engine till warm, check level, check for leaks. Make a short test drive, re-check level and again for leaks. If any leaks, tighten the bolt closest to the leak and also the two on either side of that one.
Jul 17, 2010 | 1997 Jeep Cherokee
My oil pan is leaking around the corners. What do i do?
drain out hte old oil, Remove oil pan bolts, remove old oil pan gasket, install new gasket, install oil pan, tighten oil pan bolts to 17 ft. lbs. DO NOT OVER TIGHTEN as this will distort the gasket and cause another leak.
Jul 16, 2009 | 2003 Nissan Altima
Have devolped a small leak on 2005 road king. drips from bottom of primary cover at drain bolt. running down from above. back of primary cover has slight oil dampness around transmission and starter shaft...
Spray it off at the car wash to remove all the oil , then spray Right Guard (Yes, that Right Guard) on the area of the leak. It will show up, but you may not be able to see exactly where. There are a couple spots where it can leak. The jackshaft oil seal, as you said, transmission output shaft (clutch shaft) on the trans itself, the inner primary seal where the trans shaft runs thru, the engine sprocket shaft oil seal, inner primary O-ring, the bolts that hold the inner primary to the engine/trans, the primary chaincase gasket and the drain plug. Hopefully when you get it apart, you will see which seal is leaking. If not, replace them all. Still want to fix the leak? LOL
Jun 30, 2009 | 2005 Harley Davidson FLHR - FLHRI Road...
Kenmore 44024 is leaking water apparently from the tumbler not any of the water sources or drains.
Open the lower kick panel and inspect for the source of the leak. If you feel water or see rusty or soapy residue around the tub bolts that hold the tub halves together, remove the cabinet top and tighten all the bolts around the tub. The bolts should be snug when tightening. If the bolts are ok, feel all around the outside of the tub for holes or cracks.
Mar 04, 2009 | Kenmore 44102 Front Load Washer
Hobart AM14-253 Free-standing Dishwasher Logo
93 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Garth Jackson
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
