Question about Infinity Overture 2 Speaker
Infinity 2 overture speakers- 1 wasn't working so I replaced the fuse. Now it works but doesn't have the same sound output as the other. Any suggestions?
  • 32 Answers
Verify that the bass levels are set the same on each speaker. If they are and the problem occurs on all program material, you most likely have a bad driver or amplifier in the speaker. One other thing to verify is that the balance or output levels of the left and right main speaker outputs are set equally on the receiver.
Good Luck,
BB
Posted on May 16, 2009
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
Reolacement plate amp for infinity tss 1100 subwoofer
Hi my name is MIchael and I repair the following amps JBL PB10, PB12 If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR PB10 PB12 - you will find us ... Edwards Electronics ....
Apr 29, 2012 | Infinity TSS-1100 System
Amp blown from power surge and need new amp for ovtr-1 powerd speaker were can i get one cheap
  • If it were me i would go with this. http://www.apexjr.com/inf.html $60usd not a bad deal and it looks like they throw a crossover in with it. It is actually the amp meant for your speakers.
Regards, Tony
May 01, 2011 | Infinity Overture 1--Single Speaker
My infinity overture 3 crossover does not work anymore (both sides of the crossover do not have any output. If I bypass it the speakers do work (obviously without the filtering) My question is how do I...
This is a 3-way speaker; specifically which speakers do you hear something from and which speakers do you hear nothing from? If the woofer amplifer is blown, for example, you will hear nothing from the woofers, but will hear sound from the midrange speakers and the tweeter.
Feb 14, 2011 | Infinity Overture 3 Speaker
Why does the red light click to green without the speakers on?
That system responds to signal input, ie an electrical signal present on the input, in order to turn on the internal amplifier. If it is turning green without any input from the source, it could require service. It may be responding to static electricity...
The speaker should go to sleep after ten minutes or so, turning from green to red again.
Jan 13, 2011 | Infinity Overture 2 Speaker
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Infinity Overture 2 Speaker Logo
329 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Matthew Spark
Matthew Spark
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
