Question about Troy Bilt 5.5hp Self Propelled Mower
After changing oil in troy built riding mower the oil light is still on and wont crank
  • 137 Answers
That is a safety feature with a lot of engines, there is a reset somewhere, call your Troy built dealer and ask him, I'm sure he will help. I will be a simple fix.
Posted on May 17, 2009
What is the battery size for a Troy built riding mower?
call your troy built dealer and ask it depends on motor hp etc which we do not have
Sep 12, 2016 | Troy Garden
My troy bilt riding mower wont crank
Check your battery and see if its fully charged. I had a battery that the charger said was fully charged but a cell was dead. Take it to a battery store and they will check it free of charge.
If that's not the problem check all the battery cables on both ends for being tight and clean. If that's not the problem you could have a bad starter.
Jun 22, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Why is my 8.5 hp troy built snow blower leaking oil while under strain
Make sure the crank case is not over full when not running and make sure the crank case breather is clear.
Dec 15, 2013 | Troy Bilt 5.5hp Self Propelled Mower
What type of oil do I add to the tb146 ec crank case, troy built cultivator, how do I know if there is enough?
oil is of a preference, I would use that same that you use in you car, fill it to the top of the bottom of the oil plug. Hope this helped Tim
May 22, 2011 | Garden
DOES TROY BUILT PONY MODEL # 394358 HAVE A OIL FILTER 17.5 HR 42" CUT
Your owner's manual indicates to change the oil and replace the oil fitler on page 19 as part of the regular maintenance schedule. Whether or not your exact engine application does indeed have the filter is the engine manufacturer's option. Here is your manual.
http://www.troybilt.com/wcpics/TroyBiltUS/en_US/wwcm/769-03502.pdf
Apr 22, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
My lawn mower is trying to turn over but won't completely. we have replaced the starter, battery, and spark plug. why will this not crank and turn over?
It probably has a faulty starter solenoid which won't allow full amperage to the starter. Also the valve clearances need checking because if they are too loose the built in decompressor will not work and allow the engine to crank over. Regards Phil
Apr 15, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
357 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
