My new remote rmt 15 will not work on westinghouse ld4065 do i need to reprogram ? if so how?
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
SOURCE: How do I program a remote control rmt-21 to work on a Westinghouse cw40t6dw tv?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
