Question about Hoover U5227-930 Elite Upright Vacuum
Replace the belt
How to get at the drive motor in order to replace the belt
  • Anonymous Nov 03, 2007
    How do you get to the drive shaft to replace the belt?
Have hoover breathe easy upright vacuum cleaner that needs the belt replaced. I have the belt how do you replace it
Posted on Sep 17, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
On the bottom there is a few screws remove cover and there is a roller brush there and the rest should be self explanitory
Posted on Jan 17, 2008
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
My dyson is making a loud scweeky noise
www.sewvac.com Remove the bottom plate and disconnect the belt.If it still makes the noise it is the lower motor that drives the brush that is bad.If it dosent make the noise try cleaning off the hair and debris from the motor pully and replace the belt you will need to take the brush out to do this.While the brush is out check the ends for binding they should turn smoothly with very little resistance also check the area the belt rides on the brush and make sure there is no dirt buildup in the area the cogs of the belt ride in. If it is the lower motor and is less than 5 years old call Dyson and they will generate a work order for a service provider.It may very well be under warranty. !-866-693-9766
Jan 28, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How can I get to motor drive on g4 does it have a belt
The power drive has a geared belt on the end on the armature which operates the power drive. The power drive has been out since 1990, and I have yet to see a bad drive belt in 1000's of repairs. The drive unit itself will fail very infrequently, and need replacement. The belt can be accessed be removing the handle, switch plate, and upper motor shell. The power drive unit must be loosened and dropped down to remove the belt.
Dec 15, 2010 | Kirby G4 Bagged Upright Vacuum
Turn on motor just humms
If the motor is actually running and not picking anything up, I would believe it to be either a broken drive belt for the beater brush or the beater brush is frozen or both. Remove the beater brush and clean, paying special attention to the end pieces that hold it into the vacuum. If possible spray a little WD40 on them to be sure they turn freely on the brush. Also a good idea to replace the belt, but be sure it is installed correctly in order to have the brush move in the proper direction.
Sep 16, 2010 | Oreck XL2800 Bagged Upright Vacuum
Where is the belt located?
The "belt" is normally the drive device that turns the beater brush found on the bottom front of the vacuum. Its purpose is to beat the rug and cause dirt and debris to rise up from the carpeting and be sucked into the vacuum. If the belt is missing, you may not see it. If the belt is in place, it will loop around the beater brush and back to a drive motor. Since belts can break on a regular basis any covers over it should be easy to remove via small slide levers or at most by removing a few screws from the bottom of the vacuum. The new belt must be attached properly in order for the brush to move in the correct direction. If you are going to replace the belt it is probably a good time to clean the beater brush and lubricate the end pieces of the brush with some WD40 as well.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Belt installation
You will have to slip the belt over the motor shaft and strech it down to the brush roll that should be loosened from the bearing rest, slip it over the brush and strech brush back into position.
Sep 13, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
I need a new belt drive gear.
Here's the Bosch website where you can order from the parts list . http://www.boschappliances.com/site_tools/orderparts.aspx?menu_id=34&menulevel=0304 Then click on Order Accessories and Additional Parts spacer.gif spacer.gif Looking for accessories for your Bosch range or cooktop? Or perhaps you're looking to purchase additional parts? Order here. blue_arrow_rt.gif
It will take you to another window. Type in the Model # BUC11700UC. It'll display the picture and part number. Click on the part # to order.
Nov 07, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Hoover U5227-930 Elite Upright Vacuum Logo
252 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
