Question about Dell PowerEdge 1600 ( pe1600sc/118/np ) Server
Keyboard, mouse, screen do not function?
Changed a fan (heat sync) in my dell power edge 1600 and reconnected all. turned on the machine and the keyboard, mouse, screen are not funtioning? Any suggestions what to do next?
  • 558 Answers
You may have a bad mother board or power supply,however try a few of these,bare bone the system,no mouse keyboard,only monitor,remove all internal cards,power on.If no go remove memory ,power on if you get beep tones the motherboard is good.Question for you did the fan turn during these steps.Do you have a amber light on the power button,if you do the answer is you have a bad power supply.
Good luck
Posted on Sep 03, 2009
Suppose the numeric keypad of a keyboard is not functioning correctly, and when a numeric key is pressed, the keyboard redirects the cursor. Provided that the keyboard is not faulty, which of the foll
what os youre using ?
if windows os then maybe the mouse keys on Accessibility feature was turned on
how to check it on windows 8 :
1.Swipe in from the right edge of the screen, and then tap Search. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
2.Tap or click Settings.
3.In the search box, enter Change how your mouse works, and then tap or click Change how your mouse works.
4.Under Control the mouse with the keyboard, check the Turn on Mouse Keys check box, if selected then deselect it and then click OK.
On Windows 7 :
1. goto start -> control panel -> ease of access center
2. click on use make mouse easier to use
3. check the turn on mouse keys check box, if it checked then deselect it
4. clik ok
Sep 20, 2014 | Computers & Internet
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
The keyboard is locked
Dear Sir,
plz folow this step to unlock keyboard
  1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
  6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Thanks For Your Time,
Apr 13, 2010 | Dell adamo PC Notebook
Dell keyboard locked up
Dear Sir,
PLzz folow this step to unlock your keyboard
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    Just changed batteries in my wireless mouse.
    there will be a button on your mouse. Press it to sync the settings with your laptop and it should start to work.
    or else
    click start
    right click my computer
    properties
    hardware
    device manager
    ?mouse and keyboard
    scan for hardware changes
    Feb 26, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    Keyboard is not responding it does sometimes then stop again
    Step 1
    1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    Mouse and keyboard suddenly stopped working on Dell b110 desktop
    Disconnect external peripherials except keyboard and mouse .Disconnect the power cable.Hold the power button for 10 seconds to drain flea power.Reconnect the power cable and turn on the computer When the blue DELL™ logo appears, press immediately. In bios there is option for Function key F9 or F10 probably to reset to defaults.SAve and exit and restart the system .Then try to use the PC restore feature on dell. check http://support.dell.com/support/edocs/systems/dim1100/en/SM/syssetup.htm#wp1055545
    Good Luck.
    Apr 05, 2009 | Dell Dimension B110 PC Desktop
    The mouse on Dinovo edge keyboard not working at all
    It is possible that your touch-disk is turned off. Try pressing the Fn key (RHS of the space bar, between the alt and ctrl keys) along with the "right mouse button" (the right button underneath the touch disk) -- when you press the Fn key the word "On" will light up above the button.
    If that is not the problem, perhaps the driver software was not properly installed or the keyboard is defective. You could try reinstalling Logitech's software.
    Good luck.
    - Les.
    Mar 26, 2009 | Logitech diNovo Edge 9676850403 Keyboard
    USB PORT NOT FUNCTIONING
    does your machine make it to the windows login screen, or does it fail before.
    I think you haven't installed you CPU correctly, or maybe did not put heat sink compund evenly on the heat sink, and that causes the CPU to overheat and freeze.
    Mar 23, 2009 | Mercury P4VM800M7 Motherboard
    Dell Inspiron 1000 Disassembly
    The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
    Mar 14, 2008 | Dell Inspiron 1000 Notebook
    Dell PowerEdge 1600 ( pe1600sc/118/np ) Server Logo
    159 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
