Question about Zanussi FJS1225W Front Load Washer
Not sure whats wrong with my washing machine!
I do not really know what is happening with my machine. I do set everything correctly e.g
1. FABRICS- cotton, delicates or wool etc.
2. TEMP- 90, 60 or 50 degrees
3. SPEED SPIN- 120, 900 or 700
4. OPTIONS- pre-wash, quick wash etc.
5. AUTO DRY- iron dry, store dry etc.
After doing everything, setting the cycle to 2.31, the machine starts well, does everything (washes, rinses) goes down to 1.36 then stops without drying and without getting to zero(0). therefore as far as am concerned the machine is not doing a perfect job coz i have to hang the laundry to dry in the house.
  • Anonymous Mar 23, 2014
    how to dry ur laundry in ignis
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
Posted on Aug 04, 2008
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 01, 2008
4 Suggested Answers
SOURCE: Will not spin dry at the end of the wash cycle
How do i get to the brush of a kenmore elite to check it. ia m having the sme problem. My washer works until the spin cycle. i here the motor running extremely loud he button rotates but washer still does not spin.
Posted on Mar 09, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 56 Answers
SOURCE: Error E20 showing ........stops during wash cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Posted on May 12, 2009
My Lg washing machine wd-1049 never seems to get anything in the filter, now has a bad smell, washer works fine, hose has no kinks, but it just doesn't seem to collect any 'gunk',
Gunk is from wrappers left in pockets, cheap fabrics throwing off gobs of lint, etc. no gunk is normal for good fabrics and emptied pockets. As to smell: do not use fabric softener use white vinegar in its place, and use powdered detergent instead if liquid detergent. Liquids leave residue and the residue leaves build ups which can mildew. I know that's counterintuitive but that is what happens.
Oct 30, 2017 | LG Washing Machines
What should the tension be when sewing sheer fabrics lije organzas?
Generally, for lighter weight fabrics, you would want to loosen the tension. Of course, you can accomplish that partly by using a lighter weight thread in the top and bobbin. Be sure to use a smaller needle, like a #70/10. If your machine has a presser foot pressure setting, you may want to adjust that as well.
Understanding Thread Tension Threads
Sewing Machine Pressure Settings for Machine Quilting
Dec 12, 2015 | Sewing Machines
I have Kenmore sewing machine model 385.19112. The stitch is loose and jumps. I followed all the instructions in the owner's manual but I still have that problem and on all fabrics. What can I do?
So many reasons for this.
1) the needle is not inserted correctly.
2) the needle is damaged.
3)the foot is not attached correctly.
4) the machine is not threaded correctly.
5) wrong needle size for the fabric.
6) Poor quality thread.
7) Bobbin case not threaded correctly.Hope one of these helps.
Apr 14, 2015 | Kenmore Sewing Machines
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Sep 14, 2014 | Indesit W 123 Front Load Washer
First time on Brother XL 2610, threaded correctly but thread will make loops and then pull apart. WHat went wrong?
try adjusting the upper tension
change the needle
if you recieved a instruction manual with the machine, look for the part that tells about what fabrics go with which needles, & the thread should move easily thru the needle eye with out any problem
Apr 12, 2012 | Brother XL-2610
I washed some very dirty baseball pants on Whitest whites, with bleach and Tide detergent. Not only are the pants still "tan" from the dirt but all the other whites are also "tan." I ran them through a...
Try this: Soak the stained clothes in a solution of 1 quart of warm water, 1 teaspoon of liquid dish detergent and 1 tablespoon of white vinegar for 15 minutes. Then, rinse with water.
If this doesn't get everything out, then wash in warm water (or what the fabrics allow) using a color safe bleach and detergent.
The problem is that there was more dirt than what your detergent could handle. If you have a really dirty clothes item in the future, get as much of the dirt off using a vacuum or by soaking alone as you can. Then wash the item in warm water with detergent and color safe bleach.
Sep 28, 2017 | Kenmore Elite 45986 Front Load Washer
My needed is too far back and hits the foot and cannot get to the fabric. I have tried everything I can think of and cannot get the needle forward. All the controls for side-ward motion etc are working...
is it just the needle or the whole shaft? I would try 1 make sure the presser foot is correct one for the stitch,2 changing needle, 3 rotate shaft (needle out)manually slightly pull forward on might have come disengaged
May 12, 2010 | Husqvarna Viking 1
Sewing newbie needs help
I haven't seen this machine before but in general, the most common problem is the bobbin. Either it's not wound correctly, poor thread or put into the machine wrong. Other wise wheel number 3 looks like a stitch selection dial to me. Try turning it and see what happens to the needle. When you change from straight stitch to say zig zag it would move right or left. On dial #2 isn't there some writing? What does it say? In general there is no need to change the tension of the bottom thread unless you are sewing extreme fabrics such as leather and silk. What is the range of numbers on the dials? Try putting them in the middle of the range to see if it has an impact of the quality of the stitch. My bet is on the bobbin thread not being correct. Try taking it out and putting it in so that the thread is traveling into the bobbin case from the opposite direction. I'd try this after taking out all of the thread (if it came with the bobbin) and reloading it. A straight thread on the top happens when the top thread tension is too tight if I remember correctly. It is stronger than the bottom and doesn't move so to speak.
Feb 03, 2008 | Singer Featherweight II 117
Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Nov 19, 2006 | Kenmore 24902 Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
1,148 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
