Coleman forced air furnace
Last night we smelled something burning and realized it was the furnace. We looked and the air filer had fallen down and the fan stopped. It is still putting out heat, but the fan will not come on. Any ideas?
  • Anonymous Mar 15, 2014
    not blowing fan motor not coming on
    Problem Solver:
  • 7 Answers
Im assuming you are running a/c and not heat...Was the filter burning??  if not and there are no other obvious burnt wires then id say you need a new motor. The filter, if it was'nt binding the blower wheel or wrapped arround the motor shaft would not have caused the prob.
Posted on Oct 16, 2007
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 21, 2017 | Heating & Cooling
I have a lennox furnace that woke me up with a burning smell coming through the vents. I went downstairs and checked the furnace and found nothing on fire. Turned thermostat down from 68 to 64 and burning...
Hello
Its possible the motor is going bad,more likely the blower wheel assmebly needs to be cleaned.
Have a look at the blower motor assembly for dust and dirt on and around the blower motor and wheel.Clean it off with a damp rag and a vacum cleaner.
Check the area for any trash or loose stuff that could be causing this smell.
Usually when a motor goes bad it will run for a while then slow down,then stop on thermal overload.
Then when it cools off it will restart.
Feb 10, 2011 | Heating & Cooling
COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Running out of LP??
Yes. The ignitor is trying to find fire and it can't. That's an ignition error. It should go away once you get fire to the sensors. You might have to hit a reset button, it all depends on the heater.
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Nov 07, 2008 | Heating & Cooling
Coleman mobile home furnace...Model number DGAA077BDTB...The furnace about a month ago started going out ( flash code- Combustion Air switch stuck closed)We replaced the thermostat on the wall and it...
I had the same errror code on my coleman furnace (3 flashes combustion air switch failed to close) but at first didnt realize there was even a light that gave codes..Anyways long story short, after searching many forums one guy mentioned about the furnace giving a false reading and talked about improper air flow ( coming in and going out) which isnt triggering the switch correctly. After thinking about it and after getting the furnace to run correctly every time I took the door off to tap on the switch (and other spots not knowing what the problem was yet) I always put the door right back on then the furnace would do the same thing (stop running). so I pulled the door off again got the furnace to work properly and left the door off and tested it. It ran great, it started and stopped like normal for a hour and realized I might not be getting proper air flow. Then I remembered I asked my roommate to change my filters for me while I was gone (which he did) and looked at them while I still had the door off and realized the filters were in backwards! which resticted the air flow so much the switch wouldnt operate fully. so check your air filters, something so stupid almost cost me a house visit by the furnace guy....this may not be everyones problem but maybe I will help someone save a house visit....I still cant believe that was my problem and the furnace is still running great.
Mar 14, 2008 | Dishwashers
Heating & Cooling Logo
217 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
