Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hitachi big screen tv
 The green in the picture has separated for the puple(red and blue).
The green bends at the tops and bottom towards the center.
I have no manual the tv was a gift. It's only four yrs. old.
   thank you for any help.
  • Anonymous Nov 08, 2007
    haviing similar problems. picture appears to be darker. a whole lot of blue and red very little of anything else. picture shows a lot of yellow on faces and background.
  • 1,694 Answers
Convergence IC's bad==replace and then
re-check alignment
Posted on Oct 23, 2007
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi projection tv
I would change both ICs STK392-110 and also the 3.3ohm 1 watt resistors and the 1.8 ohm 1 watt you would need 2 of each resistor. Then your convergence would be new again. You can get replacement ICs and resistors at the following link with free shipping and free instalation instructions with pictures.
Jul 01, 2008 | Televison & Video
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
