Question about Freestyle Mongoose Bmx & Owners Manual - Bike / Bicycle
Loose/ broken bracket axel
The bracket axel has come out, unable to screw or force it in.
Is there a way to remove the pedal? Can the axel be stripped?
  • Joel
    Joel May 11, 2010
    Do you want to remove the left side pedal? Try turning the pedal bolt clockwise. It may have reverse threads. The bearings on the left may also have reverse threads. So to screw them in, you would have to turn counter-clockwise.
    Good luck,
    Techjoel
  • Michial Gueffroy May 11, 2010
    Are you talking about the axle that the pedal rotates on that screws into the crank arm that the gear is mounted to or are you talking about the axle(bottom) bracket that goes through the frame of the bike ?
  • 749 Answers
Use a crank arm puller, somthing that looks like thisloose/ broken bracket axel - 5683e00.jpg, so you wont damage other parts.
Posted on May 25, 2009
How do I change front drivers wheel bearing on mitsibishi colt equipe 2005
Take off the brake assemble meaning remove the roater caliper clean any dirt off the control arm and axel mount take down the upper and lower ball joints then pry them down to allow the axel carrier to pivot down then there should be three bolts behind the bearing remove those and rent a barring puller from autozone then apply the puller to the barings and they should come out this May require a press installer or as in removing the barring you might have to use some wd-40 to spray on the back side of the barring and some hits with a sludge hammer to break it loose if the puller isn't allowed to force the barring out simply and to re assemble it is just the opposite also grease the axel shaft and make sure the surface is clean before installation and use anti seize on all screws and ect this shall help you out
Mar 23, 2014 | Cars & Trucks
I am in need of help. For some reason my brake lights come on all by themselves. The car will be sitting in park, not on and the lights just come on. I have to go and hit the brake petal to get them to...
check brake light switch where the brake pedal arm is.the brake light switch is loose or broken.or bracket holding brake light switch is loose or broken fell out of position. the brake light switch suppose to be touching the brake pedal arm to turn off brake lights.if switch not touching pedal arm.switch is broken,if brake switch touching brake pedal arm,and brake lights still on.replace brake light switch.
Apr 06, 2011 | 2001 Pontiac Aztek
Replace rear tail light on ford focus wagon 2000
http://wiki.answers.com/Q/How_do_you_replace_the_tail_light_assembly_on_a_2000_Ford_Focus_SE_Station_Wagon
abar_a.gif?v=77611 Remove two screws and rotate to the side
To remove the rear light assembly for access to turn signals and brake lights:
1) Open the trunk to expose two screws.
2) Remove these two screws.
3) There are two brackets still holding the housing onto the car. Do NOT pull up and do NOT pull up on the housing; you will break the plastic pegs on the lamp housing.
4) Referring to the driver side lamp housing and facing the back of the car:
a) You can see these pegs and brackets on your left hand side if you pull the light housing GENTLY outward. The pegs are pointing into the vehicle from the left side of the car and stick into holes. There is also a spring bracket holding the housing on where the screws are.
b) To remove the housing from the brackets, push/pull the right side of the lamp housing outward and to the left. Do this carefully so that you do not break any of the plastic pegs. What you are looking to do is detach the housing from the spring bracket, and then push/pull the pegs from their holes. You are simply rotating the lamp housing out of the brackets.
Simply mirror instructions for removal of passenger side housing.
Replacement:
This part is a little easier. Line the pegs up with the holes, and then push gently to line up spring bracket with it's hole. Then, push with a little force to get the spring in the hole. Make sure the pegs are in their holes or else it will be crooked and loose.
Take your time! You do not want to break the plastic. It should eventually come loose. With any plastic on your vehicle, be careful not to force it. Good luck!
Read more: http://wiki.answers.com/Q/How_do_you_replace_the_tail_light_assembly_on_a_2000_Ford_Focus_SE_Station_Wagon#ixzz197C2shUn
Dec 25, 2010 | 2000 Ford Focus
How do I remove the brake light stop switch from brake pedal?
disconnect the battery negative terminal from battery. depress and hold down brake pedal, then rotate the brake light switch about 30 degrees in a counterclockwise direction and remove it from the mounting bracket. unplug the electrical connector from the switch and remove the switch. to install new switch, grasp the new switch plunger and pull back until it ratcheted to its fully extended position. depress the brake pedal as far as it will go, then install new switch in the bracket by aligning the index key on switch with the slot at the top of the square hole in the mounting bracket,rotate the switch about 30 degrees to lock the switch into the bracket. gently pull on brake pedal until the pedal stops moving. the switch plunger will ratchet backward to the correct position. do not use excessive force when pulling back on the brake pedal to adjust the switch.
Apr 26, 2010 | 1998 Dodge Caravan
I want to remove front axel driver side please
Basically, you loosen the axle-nut (could be pretty tough, so spray some lubricant on it) and the wheel nuts. Jack up the car and support it on jack-stands.
Reomve the brake calipers and tie it up to frame. Remove the two bolts holding the struts bracket and steering-knuckle. Push down/sideways to separate both strut-bracket and steering-knuckle. Use large screw-driver or pry bar to pry off axle from side of transmission. Block-off transmission fuild with a nylon rag or similar; take out axle-shaft. Installation is reverse of removal.
Nov 09, 2009 | 1997 Ford Escort
Broken belt tensioner. How to replace?
HI begin by disconnecting battery , remove alternator then remove the two heater hoses attach to tensioner bracket by removing the to front screws, you will lose coolant so put a pan on the bottom .Then remove bolts attached to tensioner bracket.it will require a little force to pull out yest make sure you got all the bolts out before applying force. Here is a picture tensioner and bracket assembly so you can see what bolts to remove. let me know how it turns out it is not so bad to do5e1c732.jpg
Sep 25, 2009 | 1998 Oldsmobile Regency
How do i change the rh diff axle seal on a hyundia accent 2002 auto
place the vehicle on a lift (preferred) and remove the RH front wheel. Remove the driver axel retaining nut (1 1/4" nut) and washer. Remove the lower ball joint retaining nut (17mm nut). Using a 10 oz hammer, strike the nuckle where the lower ball joint is attached to it (be careful not to strike the grease boot) while applying downward force on the lower control arm until it pops loose. Once loose, pry down on the lower control are while simultaneously moving the strut to one side untill the joint is clear/away from the knuckle. Now remove the drive axel from the the spline of the hub bearing. Using a pry bar, pop loose the axel from the transmission differential. Installation of the new axel is in reverse order.
Sep 01, 2009 | 2002 Hyundai Accent
Unable to remove old axel so can put new one in sure need some help
Most short shafts just require a pull. Jerking works better than pulling.
May 02, 2009 | Plymouth Voyager Cars & Trucks
Shifter sloppy, having trouble getting it into gear.
There is a bracket with two torx screws that gets loose. You need to tighten that. You will need to remove the plastic and metal shield under the dash, above the brake pedal to see the bracket. Look up above the brake pedal and wiggle the the shift lever and you will see what needs tightened. Worked for me.
Oct 01, 2008 | 1996 Mercury Grand Marquis
Freestyle Mongoose Bmx &  Owners Manual - Bike / Bicycle Logo
202 people viewed this question
Top Freestyle Cycling Experts
Michial Gueffroy
Rommel Balcita
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a Freestyle Cycling Expert? Answer questions, earn points and help others
