When the phone powers up if you touch any key it just switches off then it will not switch on again and I have to remove the battery then put batt back get it to switch on
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
Process 1.. 1. Switch the power off from the back of the product, wait two minutes, then switch it back on again. 2. Check the power cord; try connecting it to another power socket. 3. Check that the product is properly connected in all other respects. 4. Switch the power off from the back of the product; remove the Formatter; reinsert the Formatter; switch the power on again. Process 2.. 1. Turn off the product with the Power Key on the left of the Touch Control Panel. 2. Press and release the Power Key to turn on the product. 3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel come on and then press and release one after another the RIGHT -> HOME buttons. 4. Wait for the unit to complete the booting process. The logs are now enabled in the product even if the product hangs and shows a system error. Once U got the error, check the error related spare, replace it, any help post your query.. Formatter snap:
First Try it: You may try default phone and security code to remove it Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. If Soft reset( factory setting)
On Sybmian phones: *#7780# - Restore factory settings *#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone. 1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step. You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember. 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Remember. 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting. Hope this helps.
Again do it please, Just follow the steps Make a backup of contacts in your another Sim. Switch-off your phone. 1. Press and hold there keys at a time;
Green dial key, * Star key, No. 3 key Then Power on/off to switch on the phone. All switch will be pressed at a time.
.Soon an formatting text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting. Hope this helps.
hard reset wil delete all your data including phone book contacts. power off phone ,remove back cover, now hold volume keys both up and down together, press power on button also then using stylus press the reset switch, let go the power on and reset some message will be displayed on the screen , now release both volume keys, the just volume up key again to begin hard reset.
comment when done
Do this : *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message. (Rate me pls!) Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
The touch sensors would have lost its power, just try to switch off the mobile and remove the battery and put it again it will solve the problem only temporarily, and if still the problem persists then get that replaced.
If yuor waranty is over, then you can just open the phone and remove the plastic slider. Then close the phone and use the stylus to operate the exposed key lock switch. This is the simplest way, i found. The plastic slider is very delicate and is very likey to break if you slide it very hard or after a few thousand times of lock/unlock operations. This is something Motorola should have thought about before designing it in. Like Nokia or HTC, they could just have put the screen lock control in the power switch/ phone on-hook switch itself.
