Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Replaced blades on Craftsman 21.5 HP B+S engine Model 91-7272460
I replaced the 2 blades after sharpening them , now it does not cut the grass , seems like the blades do not spin.
  • Dwain Pippen May 11, 2010
    You didn't say whether or not you had been using it previously. Was this the first time you tried to use it this year?What happenes when you push the engagement lever up on your dash? Is you belt on your pulleys? With your engine OFF, kneel down and look at your deck while you, or someone else, engages the lever on your dash. Does that tighten up the belt? The right side idler pulley should move toward the rear of the deck to tighten up the belt. The arm that the pulley is on has a pivot point and may be rusted and not be moving. Some things to check. Let me know what you find
    Problem Solver:
  • 7 Answers
You might want to check this may sound silly but check to see if the blades were put on upside down.
Posted on May 17, 2009
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
4 hp craftsman edger/trimmer. Not getting a clean cut anymore on my grass.
Does this one have a metal blade? If so the blade is removeable for replacement or for sharpening.
Aug 06, 2011 | Craftsman Garden
New yard man 21''-- mulching -- too much grass comes out left front wheel area and covers engine when cutting -- help...
Maybe try removing that blade and checking it/sharpening it. You could also install a new blade or a 21" mulching blade that is designed a little different, giving a different cutting process and results. When the grass comes out by the left front wheel, have you shut the mower down and checked for any kind of grass build up under the deck?
Sep 15, 2010 | Garden
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
160 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
