Question about Kenmore Elite 45986 Front Load Washer
Washer not working
My washer was unplugged for 2 days, when we plugged it back, on the remaining time place is the number 16, but it won't start washing or won't delete the number 16
  • 6,784 Answers
Hi, your control circuits are locked. you will need to replace the microcomputer in this unit. it is malfunctioning.
Posted on May 16, 2009
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
Kenmore Elite HE4t Washer won't start
Hello Ameliafaith,
E-Z job...
If you take your model on line... to SEARS
(I don't ordinarily recommend)... BECAUSE THEY COULD ACTUALLY ... decode your ABREVIATED part number...
110. blah blah blah... (45986??)
The other sites actually have helpful VIDEOS...
But I already wasted enough time on this floundering with your
erroneous number (wrong no.)...
You will see these parts are reasonably priced and
very popular.. meaning they INDEED FAIL ... alot.
Go here:
Washer Door Lock Assembly Part Number 8181700 Sears PartsDirect
Carnac the Magnificent
Jun 07, 2017 | Kenmore Elite 45986 Front Load Washer
Computer ramdomly turns off
Instead of unplugging everything, only unplug 1/2 of the things. If it still won't start, unplug 1/2 of the remaining things (noting which ones they are). If it restarts then, it was one of the last set of things you removed that is the problem, so keep eliminating possibilities in this fashion this until you can determine which component it was. If it turns out to be the power cord, it could be a problem with the power supply.
Mar 02, 2012 | HP Computers & Internet
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
Door locked. drain & spin flashing. time
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore Washing Machines
Get dl F error code
1. Unplug washer.
Jun 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Dec 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Roper washer wont spin or agitate.
It sounds like you have a broken coupler. (a hybrid plastic/ rubber gear that acts as part gear, part shock absorber). To verify this, first unplug your washer. Pull it forward slightly and tilt it back about 6". Use a flash light to show you the underneath side. You will likely see black shavings, peices of white plastic, or possibly even a mangled chunk of black rubber. This is what is left of your coupler. If ou are able to verify this, grab your model number( the one supplied [ras6223kq] does not come up aa a vailid number). Just lift the lid and look towards the rear where the lid and top of the unit meet. In the center where they meet you should see a plaque with your model number in it. Once you have your replacement coupler, here's how you replace it. 1st - Unplug the unit. Next, open your console. The most common ways to do this are either 2 phillips screws on the back of the console where it meets the top of the washer on the right and left hand sides or there are 2 cosmetic caps on the front of the console. Once you remove the caps, you will find 2 phillips screws to remove. Once the screws are out, pull the bottom of the console towards the front and swing it up. (it should be hinged). Underneath, you fill find 2 large brass colored clips. Find the area where the clips go into the top of of the unit. Use a large screwdriver to simultaniously push down and push the handle towards the back of the unit. This will let the clips out. Now, open the lid and grab the opening for the clothes and pull it towards you while placing your foot at the bottom center to keep it in place. Once you reach about 45 degrees forward, let both the bottom and the top come forward slowly at the same time. Now with the cabinet out of the way, look towards the bottom center of the machine. You should see a white piece of plastic with two black hoses connected. That is your pump. Pry off the two clips holding it on. Underneath is your motor. On the right hand side there is a wire harness. Follow the 2 red wires. This is your capaicitor. If you touch the metal parts is can kill you. So, pull the wires off, then touch a large screwdriver across the two metal plugs where the wires just were. It is now safe. Unplug the rest of the wires where they connect to the motor. There are 2 more clips keeping the motor in place. First remove the screws (they will be either 5/16 or 1/4" screws). Then again pry the clips off. There is a shaft on the back of the motor and a matching shaft behind it on the transmission. Remove any remaining coupler pieces. (you may have to pry or break off the remianing pieces) Take the new parts and press them on the shafts (I find using a spark plug socket and a hammer to press it on works best). Now re-assemble in reverse. If you didn't have the shavings or run in to any other problems, drop me a note back.
Jul 08, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
