Question about HP LaserJet 4 plus Printer
Proper Manual cleaning
Are there any instructions for cleaning the Entire printer. Perhaps even a usage cleaning schedule.?  I have the 4plus and the 4Mplus and they are the only printers that handle the gold seals. I cannot upgrade and would like to clean them properly to extend their life. Thank you
Re: Proper Manual cleaning
Hi Gidget,
I typically use "Chux" wipes and a shop-vac to start with. The wipes wipe up and REALLY HOLD the toner & paper particles, holds 'em tighter than a Hobo does a ham sandwich...
(I'll concede to the 'by-the-book' crowd that a specific (read EXPEN$IVE) type of vacuum cleaner is recommended by HP & most other service org's. I've used my shop-vac for 12+ years and have serviced thousands of HP LJ's, CLJ's, AiO's, MFM's, DJ's, OJ's, etc. I have never lost a single printer because I didn't use the 'right' type of vacuum...)
The Chux wipes are available from PartsNow, LLC;
They also carry maint kits for almost every HP printer made as well as Lexmark, Canon, Xerox, etc.
I use Cooper's Platen Cleaner (PartsNow) to clean the rollers using 2" x 2" gauze squares and nitrile gloves. Fedron works well too. HP's website mentions isopropyl alcohol and water as their recommended solvents. Use waht works best for you.
Having some 6-inch long cotton tipped applicators (wooden handled single ended Q-Tips...) helps tremendously.
In conjunction with the correct service manual, (in your case,  Combined Service Manual for HP LaserJet 4L / ML & 4P / MPHP Publication Number C2005-90988, August 1993), a thorough cleaning is very easy for almost anyone to perform.
PartsNow and several other websites have HP Svc Man's online for free, Google around.
A legacy utility from HP that I've not yet tried can print and cycle cleaning sheets to clean mainly the fuser, but also claims to clean rollers as well. HP printer specialists will recognize 'cleaning sheets' from HP's newer models, built in to the menu structure. The utility will allow you to do the same for older (LJ 4, 5, & 6) printers. Find it at:
Another Combined Svc Man is available as well that covers:
HP LaserJet 4 / 4M
(C2001A / C2021A)
HP LaserJet 4 Plus / 4M Plus
(C2037A / C2039A)
HP LaserJet 5 / 5M / 5N
(C3916A / C3917A / C3952A)
HP Publication Number C3916-90984 (March 1996).
As far as Scheduled cleaning, the cleverly formatted (LOL) table below lists HP's recommended service intervals. Over the years, I've found that adhering to the schedule has reduced unplanned downtime by almost 80%!!
1.  Toner Cartridge / 1 / 6800 (note 1) / When print becomes faint, shake cartridge to distribute remaining toner.
2.  MP (Tray 1) Pickup Roller Assembly / 1 / 200,000 / Replace roller and separation pad together.
3.  PC (Tray 2) Pickup Roller / 1 / 200,000 / Look for glazing and cracks.
4.  Separation Pad / 1 / 200,000 / Look for glazing and grooves. Replace together with Pickup Rollers.
5.  Transfer Charging Roller / 1 / 200,000 / May affect print quality and/or paper jams.
6.  Fuser Assembly (115 V, 50/60 Hz) / 1 / 200,000 / May affect print quality and/or paper jams. Look for marks on rollers.
6a. Fuser Assembly (220 V, 50 Hz) / 1 / 200,000
7.  LC (Tray 3) Pickup Roller / 1 / 200,000 / Look for glazing and grooves. Replace the Separation Pad.
8.  Exhaust Fan / 1 / 25,000 hrs. (I've only had to replace one in 12 yrs...)
Note 1: The estimated Toner Cartridge life is based on A4 or letter size prints with an average of 5% toner coverage, and with the density setting at 3.
Best of luck,
Posted on Oct 17, 2007
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,346 Answers
I don't know of any cleaning manuals,  only maintenance kits which consist of replacing the tire, fuser rollers and transfer roller.
The easiest way to maintain any printer is to make sure you clean any toner leaks, paper dust out of the machine and change the tires to avoid any paper jam.
Get a bottle of air spray and open the doors of the printer remove the fuser ( back door and two screws) blow out all dust and toner from inside the machine, remove paper tray change tire and clean tray for dust. That,s it,.
0 characters
3 Points
Light wide strips printing on page.
have u checked the itb, image transfer belt.
or transfer roller
Sep 17, 2015 | Samsung CLP315 Color Laser Printer
What type of ink cartridge does this cannon pixma mp 160 printer use
Look inside the instruction book that came with the printer. It lists the proper number of the items required even Ink for your printer. You have to buy the right size. Or look online on the web under Canon PIXMA MP160 All-in-One InkJet Printer. Maybe even just look under Canon Printers and it will lead you to the correct type number of ink cartridges required for your machine. Make sure you get the correct number, size etc....and follow directions how to install. Did you know, I found out Ink Cartridges are ALMOST the SAME PRICE AS The Entire Printer???? that ink costs a bundle! at least me, I think I found my Ink replacements online purchase on sale, at OfficeMax. I had to orderr online, then go pick it up at the store itself. It was more expensive than the printer was! what the heck?????julie
Jul 04, 2014 | Canon PIXMA MP160 All-In-One InkJet...
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions....
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Dec 12, 2009 | Brother MFC-7820N Laser Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
No instructions on how to use scan. how does it work?
You will probably find all you need here:
Jun 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
Need instructions on cleaning rollers
most likely its the fuser. There is burnt toner on the fuser and its damaged
Apr 02, 2009 | HP LaserJet 2420d Printer
Kip 3000 plotter
voltage error 031-034 on the kip 3000
Jul 05, 2008 | Printers & Copiers
Printing pages dark
The cartridge itself needs to be replaced, threre is a blade called the drum cleaning blade which scrapes toner off the Drum(blue roller) it is not cleaning the excess toner.
Oct 16, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
1,407 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
