Question about Microwave Ovens
Quit working-everything I have a microwave hood combo. MH711OXBQ It just stopped working, like a fuse blew, but no fuse blew. It has power, but will not turn on.Randy
  • rjones218 May 16, 2009
    thank you, where is the internal fuse? and how do i get to it?
    yes. It was the internal fuse. found it and replaced it. Yippi. You are worth it. Thanks
    Randy
    Brigadier General:
  • 8,619 Answers
Hi Randy
If your microwave oven doesn't seem to work at all, the first thing that we check is Fuse(s) as usually, when your if the microwave oven doesn't work at all, it means the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Please check the Fuses again. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If both of them are fine then most microwaves today have a flame-oven thermostat-safety built into them. This oven thermostat will open up (no continuity) when something has been overheated or set on fire in the oven. Usually the thermostat for the oven is on the top area. The flame-oven sensor-thermostat is suppose to be closed (full continuity ) all the time and will open up (no continuity ) when needed, like when something like a small fire in the oven occurs. Thanks for using FixYa.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 16, 2009
  • Rylee Smith
    Rylee Smith May 16, 2009
    Hi Randy
    Unfortunately I am unable to find its wiring diagram in my database so that I can show you where the thermal fuse is located, however it is always recommended to contact a qualified appliance repair technician for replacing/repairing any parts as these units have high voltage even when its switched off. You can also contact whirlpool at 866-698-2538 to schedule a repair service.
    Thanks
    Rylee
My hood fan quit working on my kenmore microwave/ hood combo. How do I fix?
Check to see if fan is getting power. If it is and the fan does not turn then you need to replace that motor. Also check motor bearings - not uncommon for them to get all gunked up with yuck from the air they push through the hood.
Aug 23, 2017 | Kenmore Microwave Ovens
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
Microwave quit working no power everything quit working
use the next steps and fix it. test with the VOM. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).14f03872-81cf-492a-a958-5a445dcde206.gif
Jun 16, 2013 | Microwave Ovens
Lights and fan quit working
there are fuses inside the microwave but there not the kind you would have in the house,,unless you can buy them it cant be fixed by you,
Jul 03, 2010 | Hotpoint RVM1635 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Everything quit working no power anywhere
Have you checked the fuse in the plug? Also there is an internal fuse that you have to remove the outer casing to get at. Please make sure the power is off and the plug is removed from wall socket before you start and do not power up until the casing is back on. Hope this helps.
May 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
WE BLEW 2 OUTLETS IN KITCHEN & COULDNT FIND THE BREAKER THAT BLEW
remove cover of microwave, find and check the fuse
Feb 05, 2009 | Microwave Ovens
Microwave arced, wont heat now
I'm assuming that it doesn't microwave either. If it does...then the heater is bad. Sears parts sells them. Second guess is a blown fuse or thermosensor. Inside the pad housing, locate the internal fuse and replace it if blown. The thermosensor is a black plastic bit about the diameter of a dime and 3/8 inch thick and clamped to the side of the unit inside the control area. Test it for continuity and replace if open. If not either of these, then you have power supply issues or control panel problems. My bet: the heater blew out. Often, this is caused when you heat greasy foods.
Dec 16, 2007 | Kenmore 69642 Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
