Question about HP Pavilion dv1000 Notebook
HP DV1000/screen turns on then turns off.
When I turn on my laptop the screen turns on for a second and the it goes blank but the buttons are still lit. I connected my laptop to my plasma pressed f4 and I can see it just fine. Can any body help me?
  • HP Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 17, 2009
How do i fix my LCD?
I have got a hp pavilion dv5000, when I turn on it the screen goes blank.
Power led glows, I hear for a few time the fan, disk led flashes intermittently and also I feel that the DVD player tries to load.
If I try to click on caps lock or num lock, leds don't respond to commands. I tried the hard reset pressing the power button for 30 seconds with the battery and the power removed. Nothing to be done by connecting an external monitor....
Thank you
Jun 11, 2013 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000: When I turn it on, it does not boot up and I get a blank screen. I have tried hard reset by taking out the battery and holding the power button for 30 seconds, and then turning it back...
I just want to know if you see any power indicator on the machine? If you see any power indicator try to check if you hear any sound that it boots up to windows or try to check if there are any beeping sounds when you turn on the machine. If you hear the windows boot up sound try to use external monitor and see if the machine gives any display. If you hear consecutive beeping sound it means there are hardware that's faulty inside the machine.
Apr 03, 2011 | HP Pavilion dv1000 Notebook
Computer screen goes blank. when I turn my computer back on the HP logo shows for a mere second than the screen goes blank again
The inverter boards on laptops are common failures. Depending on the age of the laptop it could also be related to a faulty LCD interface cable.
Jan 17, 2011 | HP Computers & Internet
Hi! I have HP pavilion dv1000 that works fine until just this Thanksgiving (Nov.2th) when i turned the computer the screen is just blank or black but it is still working. I am able to use the computer now...
Unfortuntly sounds like your screen went bad.
Sorry I can't give you any better help with this one, it can be fixed, just going to cost you around $100.. for new screen.
Sorry
Nov 27, 2010 | HP Pavilion dv1000 Notebook
Pavilion dv 1000 will turn on but screen turns
click start when the previous settings were working.
hope this helps
Apr 26, 2010 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 blank screen
It may not even be caused by the graphics display driver at all. Your Hard Drive may hae BAD SECTORS and the computer is battling to read the system area of the hard drive... Make alse sure that the hard drive commections are fine
Jul 08, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 PC Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
May 25, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
741 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
