Question about Sony STR-DE135 Receiver
My Sony STR-DE135 reciever has sever distortion on the right channel speakers (A&B) no matter which input is selected. I can not find any obvious fault on the board. Any tips to help me fix it?
  • 32 Answers
It sounds like your receiver may have a damaged output IC. I'm assuming that you've already tried a known good speaker on the right channel but if not, that would be a good idea. Also check and verify that the speaker wire is not damaged and that the terminals at each end are securely fastened.
Good Luck,
BB
Posted on May 16, 2009
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
My sony receiver STR-DE135 is showing a protector message
Check for shorted speaker cables, or even a bad speaker. I'd start by disconnecting all speakers, see if the indicator goes out. If so, try one speaker at a time until you find which channel is bad, and then examine the cables carefully for things like a stray wire strand. Less likely, but possible is a shorted speaker. If you disconnect them all, and still have the protector circuit on, it's an internal issue, and you're going to need a technician.
May 30, 2011 | Sony STR-DE135 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have a sony STR-de135 receiver whlie looking for one problem created another.While the receiver was unpluged I touched and output transistor MN2488 and it sparked now the left channel sounds distorted so...
The capicitors in the unit are charged. Replacing the output transistor(s) is not a task for a novist. Capicitors, resistors, driver transistors and sometime preamp chips can also be bad as well. If all the bad components are not replaced the parts you replace could blow out again.
Jun 19, 2010 | Sony STR-DE135 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Want to play my ipod through sony str-de135 receiver
Get a headpone to rca cable (radio shack or best buy) and use any input on the rear of the receiver except phono. You will need to turn the ipod to near max volume.
Nov 28, 2009 | Sony STR-DE135 Receiver
On the display of my sony str-de135 appears the word"protect" and then the cd does not work. what must I do ?
your speaker wires are grounding out on something or you have popped an internal fuse or youve burnt the power supply refer to your manuel
Oct 07, 2009 | Sony STR-DE135 Receiver
SONY STR-DE125 READS PROTECTED
protection is designed to protect the output transistors from, shorted speaker wires, shorted speakers, too low speaker impediance,make sure the amp is well ventilated.
turn the amp off for 1 to 2 hours to allow thermal reset if this fails most likley some internal damage has occured and the unit will need to be serviced
Sep 02, 2009 | Sony STR-DE135 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Sony STR-DE135 Receiver Logo
316 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
