Question about Xerox WorkCentre XD155DF Laser Printer
Why is my printer does not turn on when switch is on?
My Xerox WorkCentre does not turn on when the switch is on.The reading on the screen flickers "h2" continuously untill you switch it off. Does this has to do with the toner cartridge or the drum. Please help me solve this problem. Thank you.
The Printer: Xerox workcentre xd 155df
  • amicronmx May 16, 2009
    I am going to try to get the Manufacture part# and put it in first. I do believe your acessment and recomendation. Thank you.
  • 3,230 Answers
This error code indicates that there is a problem with the fuser warming up. Make sure all the cables are in connection and that no point is missing.
At that time you need to change the Mfr Part #: RDTCT0128FCZZ
it will fix this issue.
Thanks
Posted on May 16, 2009
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Xerox 7328 touch screen not taken
I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working.
Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support
Thanks,
Sep 05, 2014 | Xerox WorkCentre 7328 Multifunction laser...
Screen reads "printing...please wait"
If this machine has memory boards on the back, turn off the machine and take the boards out.
turn on the machine, and reinsert the memory boards.
Sometimes these boards lock up the machine.
If this does not work, the fuser may be the problem.
Oct 28, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Can this xerox workcentre print to color?
The Xerox XD100 copier/printer is Black and White only.
Sep 11, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox workcentre 470 cx problems
Those are referred to as the dots of death.
Most frequently the hard drive has failed.
Possibly firmware corruption or a main board failure. Normally not good.
Feb 23, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
At the lcd screen you can read this message: "ESCANNER DESABILITADO"what should I do?
The scanner probably got accidently locked. Turn the machine off, unlock the scanner, then turn back on.
Instructions on how to unlock the scanner are found here:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=143,E=0000000001181477675,K=8219,Sxi=11,Case=obj(349)
Dec 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
The display screen reads "L3"
that is related to the scanner. Lamp, or cable, and to be honest, it would be much less problem to replace the printer. That is a very hard machine to service and that is a difficult problem and can be very expensive to repair.
May 21, 2008 | Xerox WorkCentre XE60 Laser Printer
Xerox workcentre xd120f laser b/w printer
You can download the manual on the following link. How to clear the flashing "P" is on page 14. http://download.support.xerox.com/pub/docs/XD155df/userdocs/any-os/en/newxd.pdf
Aug 04, 2007 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre XD155DF Laser Printer Logo
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
